Although I have not used the CM, this sub average dummy thinks highly of the Zenith. Its build quality seems bullet proof. Picture quality? It looks very good. And it is very easy to use with no annoying quirks.
IMHO, the S-video over composite video argument for going with the CM over the Zenith might be a bit overdone depending on the television you use and how you view it. I use my Zenith CECB with a 40" LCD, with the viewer being some 10 feet away (master bedroom). Viewing content over S-video in such a configuration would not show any real difference over composite video. However for giggles and grins I hooked the Zenith to a 32" Vizio plasma and stood on a few feet from it. The picture quality looked weak. I would expect the CM with S-video would have produced more pleasing results.
Having said all this, if I was buying a CECB for the primary television in my house I would spend the money and get the CM. For all other applications, or if money is really tight, I would get the Zenith.
_Lazza
_Lazza
We have cable and all but one main TV is ATSC. The boxes are only for former-portable (
) TV's and for when cable goes off the air. This particular box is for an old 46" projo 16:9 without an ATSC tuner, so that's why I needed S-video. Of all the reviews I read, the CM7000 had the fewest of a box with S-video.
So all one can do is get the one that has the fewest neg reviews. Luckily in my case they'll rarely be used.
