Originally Posted by Tulli
This means the current monitor driver for the Onkyo is the Generic PnP Monitor, meaning that the EDID Override is NOT active at all, maybe because of problems with the installation procedure.
So, Right click there on that Generic Pnp device, select update driver software, then Browwse my Computer for driver software, then Let me pick from a list of device drivers on my computer, then select "Have Disk", then "Browse", and finally navigate to the directory where the .inf file is located. MAKE SURE that it's the ONLY .inf in the directory. Now install the driver and finally reboot. Try again with the samsung connected to the Onkyo and the Onkyo to the graphic card. As before, there shoul be no BIOS screen.
Anyway, best way to install the override would be to temporarily plug a VGA/DVI monitor to the primary port of the graphic card, and the Onkyo to the second (with the Samsung connected to the Onkyo). This way you really can MAKE SURE that the override is applied, as you can reboot and see if it works. If it does just disconnect the VGA/DVI monitor, reboot and see if it still works.
If it stlll doesn't work you know you'll have to get a Gefen HDMI or DVI Detective PLUS and be done with it.
Sorry man, but this is all I can do. All is up to you now!
Tulli,
Thanks for all your efforts in the past. I had to move outta that last place...not a healthy environment.
Anyways, upon reading some of your past threads I decided to go with the HDAV slim. So the new chain is:
HTPC (4870x2) --> HDAV Slim --> Onkyo PR SC885p --> Sceptre X246W-1080p 24in HDMI 2ms LCD.
Initial plug in was alright, but no drivers were installed. Went online to get Asus' Win 7 64bit, and installed them. No picture on reboot. Had to go back to ATI to Onkyo connection pattern.
Went to Moninfo.exe and had no REALTIME displays.
Uninstalled monitor and rescanned for new hardware. Generic PnP came up. Ran Moninfo.exe again, and no realtime.
So, I went back to your NX906 EDID override file. Reset with ATI to Onkyo, picture still there, NX906 read as monitor. Used the HDAV Jumper cable and got picture. Blu-ray played on TMT 3.0.13.139, no HDMI sound just 5.1 PCM. Ten minutes into the movie lost all communication (I'm guessing EDID handshake error with stubborn Onkyo/ATI).
I have Catalyst 10.1 installed. Do you have any ideas for a possible solution route?
///Arash
