It is obvious that the OP wants a 5.1 setup or he wouldnt be asking about it. The problem is the he is probably worried about it sounding like sh!t. You can find pretty good sounding 5.1 setups for that much. I am VERY VERY happy with my setup (
http://www.avsforum.com/avs-vb/showthread.php?t=990726) and it was only about 1300 shipped for the 5.1. As my advice to the OP, I would suggest getting your 5.1 setup for 1k now since you obviously want surround sound, which you can get one that sounds great IMO. While using your 5.1 setup, you can then be saving for your audiophile grade system that you want. This will allow you to buy your primo system all at once rather than piece by piece and yet you still get to enjoy good quality surround sound all the while. I agree 100% with sivadselim when he says that you've got to worry about matching when adding to your current speakers if you decide to buy piece by piece, both aesthetically and acoustically... maybe that year the manufacturer decided to tweak the crossover a bit and now the sound is off on your new center speaker or they've decided to only offer certain veneers (just an example). Additionally, a cheaper 5.1 system would be easy to sell and recoup a large percentage of the original cost that, when you've saved up for your premium system, you can put that money back toward it. So then you're really not even out that much. Who knows, by the time you save up for the goods, they may be half off
