This won't be a very big thread for a while, but I had an epiphany reading a comment from Art in the 2.35 forum, which is very true. People with scope screens are beginning to discriminate (for lack of a better word) against 16/9 and vistavision content. The width of the image portrays more spectacle in cinemascope. It is true. If for any architectural reason you are doing a servo zoom installation, in a retrofit condition and your position for the lens when in HDTV aspect ratio memory is right there at the end of the barrel , and when you macro to CINEMASCOPE you still have some range in the lens the focal superiority will apply to the cinemascope making it appear sharper. That was the case with helene. In my case I too prefer 2.40 cause it looks so darn good like - 70 mm.
HDTV just started a few years ago, now we are getting bombarded with CINEMASCOPE titles but in the near future there will be saturation, both of the ubiquitous HD format AND the CINEMASCOPE, at that time the post houses will start cranking academy ratio content en Masse- there are hundreds of classics from the forties , fifties, and sixties that will become available. What is the videophile to do?
Use Servo Zoom Lensing and multimasking screens to create a new generation of Constant Image Area home venues.
The one problem I see is the limited range of the latest first batch of servo zoom lenses. Barco only has 5, the upcoming other has a few more:
SuperKontrast MKI/II
0.98” DC2K (1.2-1.8)
0.98” DC2K (1.4-2.05)
0.98” DC2K (1.6-2.05)
0.98” DC2K (1.9-3.2)
0.98” DC2K (2.4-3.9)
(if any good )The Farbenmeister
Motorized Auxilary Lens Mount
1.05:1 Zoom Lens
1.30-1.75:1 Zoom Lens
1.39-1.9:1 Zoom Lens
1.5-2.2:1 Zoom Lens
1.75-2.40:1 Zoom Lens
1.9-3.0:1 Zoom Lens
2.40-3.90:1 Zoom Lens
3.90-6.52:1 Zoom Lens
Wide Converter Lens (WCL)
With this other projector you can use the servo zoom to handle 2 aspect ratios and then swing in the WCL wide angle adapter to increase another aspect ratio as needed. Cause these servo zooms only have enough range for cinemascope and hdtv/vistavision.
For those that do not want to use the WCL or those with a Superkontrast another solution is to mount the projector on a unistrut mono-rail system and push the p[rojector back and forth so that in combination with the servo zoom the stricktest possible CIA is maintained.
1.05:1 Zoom Lens
1.5-2.2:1 Zoom Lens
1.9-3.0:1 Zoom Lens
Things can only get better I guess.
