The sammy 1500 decodes truhd right? but it only has 2 channel analog so how could someone enjoy a 5.1 truehd track if the sammy only have 2 channel analog? and I heard there is a rumor that the sammy 1500 will be able to decode DTS HD MA through 2 channel analog converted to PCM to the reciever (like Onkyo 705) to 5.1/7.1 speaker set up? I am confused I think I will try this later with the truehd track with my samsung. Sorry for the newbie question. Or maybe the sammy 1500 will decode truhd via hdmi and converted to pcm? Is it the same case with DTS HD MA when it become available with sammy 1500 to decode?
FROM SAMMY 1500 MANUAL: I think I get it now.
Blu-ray Discs may include three audio streams.
- Primary Audio : Main audio soundtrack of the disc
- Secondary Audio : Provides audio for the BONUSVIEW
window of a Blu-ray Disc.
- Effect Audio : You may hear menu prompt sounds (etc.) when
selecting menu items (depending on the disc),
on a Blu-ray Disc.
Digital Output Selections
Setup Definition Pro Con Recommended use
PCM
Decodes Primary, Secondary
and Effect audio streams
together into PCM audio.
You can enjoy Primary,
Secondary and Effect audio
together.
You can also enjoy Dolby
TrueHD sound even if your
receiver cannot decode Dolby
TrueHD.You cannot hear DTS-HD sound
with this setting even if you have
an HDMI 1.3 receiver which has
DTS-HD decoding capability.
Recommended choice if you
have an HDMI 1.1 or HDMI 1.2
receiver which cannot decode
DTS-HD MA.
Also recommended if you are
using an optical cable for audio
and your receiver cannot decode
Dolby Digital or DTS.
Bitstream
(Re-encode)Decodes Primary, Secondary
together into PCM audio, then
re-encodes the PCM audio into
DTS bitstream.
together.
Audio quality may be lower than
PCM or Bitstream (Audiophile)
setups.
don’t have an HDMI supported
receiver, but have a receiver with
an Optical input that can decode
DTS.
Bitstream
(Audiophile)Outputs only the Primary audio
soundtrack (main soundtrack
of the movie) so that your
receiver can decode the audio
bitstream.
You can enjoy DTS-HD sound
if you have HDMI 1.3 receiver
which has DTS-HD decoding
capability.
You will not hear Secondary and
Effect audio.
have an HDMI 1.3 receiver
I hope I am not confusing everyone and pardon me for the lengthy post. So let say I have a truehd movie track with bonus view features and wanted to access the bonus view I would set up my audio into PCM and still enjoy truhd sound since the player can decode it. RIGHT?
Second if I have a DTS HD movie track with bonus view features I will hear only dts if I access the bonus view feature RIGHT?
third if the sammy 1500 can decode DTS HD MA (rumors say it's gonna happen) it is safe to set up my sammy into PCM and still enjoy DTS HD MA but it will show as PCM in my Onkyo 705 receiver RIGHT?
Wow this is great if the rumor becomes true. We will have a player comparable to PS3, S550 and bdp50 in terms of the great PQ we get but also the internal decoding of all new codecs. anyone can comment to this?
