AVS › AVS Forum › Video Components › Video Processors › Looking for HD-SDI modification board / technique
Looking for HD-SDI modification board / technique - Page 2
post #31 of 40
Bob, is there anything on the HDMI output from the Onkyo? that shouldn't matter, let me check my system and see
-Gary
post #32 of 40
Bob, just checked my system, HDMI audio in and no HDMI output connected/sinked on the Onkyo, plays back just fine
I don't know why you are having problems
-Gary
post #33 of 40
I don't either, especially when I hook up my HDDVD player on the same HDMI cable and it works fine. I need to get with JVB on this as I have two players and they are both having the same issue!
I know they waited for new firmware before shippingto me, but don't know if they checked the audio?
post #34 of 40
Finally got a chance to take a look at some HD-SDI today
amazing stuff was in store
much the same as SD-SDI, so those that have went that route should know what to expect
lots of false sharpness, noise and digitalness is gone from the image, so when you first look at it you may think softer image, but as you start watching you'll notice a more detailed image the is smoother and natural looking compared to HDMI, colors are improved as well, again they are just more natural looking and lusher, of course both HDMI and HD-SDI are calibrated to spec for my viewing
just some first glance feedback based on the Fifth Element remaster
I am going to take some images and do some hardcore test pattern viewing latter to see whats up
the BD30 with HD-SDI rocks hard!
-Gary
post #35 of 40
so whats the difference between HDMI & SDI? color space improvement or correcting a compatibility issue???
love SDI and my Panasonic plasma is equipped...
cheers
Zippy
post #36 of 40
Zip, which plasma is that? very nice
the biggest difference I see with SDI is cleaner image, it is a very small difference but it is there, I sit 1.25x back from a 7' wide screen and CRT pj, so every little bit helps
I prefer the colors with SDI as well
-Gary
post #37 of 40
its the 50PHD7UY...
so how do you modify the source device, is there an unused port on a chip and buffering it or are you taking YPbPr and converting it??? HDMI cable is wayyyyyyyyyyyy over priced at retail.
I've learned to minimize the number of A/D conversions in any system.
zippy
post #38 of 40
HD-SDI requires about a 800$ mod to output the signal
-Gary
post #39 of 40
interesting, so you already have an interface board? if so, care to share any technical details?
Zippy
post #40 of 40
yes Zippy, sorry I can't really give all that much detail wise
what kind of details where you looking for though ?
-Gary
  Back to Forum: Video Processors
