Originally Posted by
ldgibson76 /forum/post/13914539
hello "rodH".
If the emphasis is on audio, then when it comes to the Oppo player of choice, it should be the DV-980H, not the 983. The technology in the 980 leans more to audio performance than video. It's still has good video performance, but audio is the virtue. Why? The DSD capability.
http://oppodigital.com/dv980h/dv980h_comp.asp
At $169.00, there's isn't a word or phrase available to me right now to describe the value this player offers!
That being said, although value is the strong point, that doesn't mean that it's an overall better buy than Parasound D200.
http://parasound.com/nc/d200.php
Now, at $599.00 this is a tremendous value also. You can consider this a hi-end product because a lot of the technology is past down from the flagship Halo model. The build quality alone, in my opinion puts this ahead of the Oppo. It's a beast. If the size of the D200 is not compatible with your setup, then I would suggest the NAD T585 at $499.00.
http://nadelectronics.com/products/d...sal-DVD-Player
Although, not the build quality of the Parasound, but a formidable player in it's own right.
And finally, if money is the virtue, than the Oppo is the obvious choice. Nothing to be ashamed about if you choose this player.
They all share similar technology at different levels.
I hope this helps.
Regards.
I hope this helps.
