I'm in the market for a new projector and I have no idea where to start. I picked this forum as I know I want to spend less than 3 grand. At this point the only two projectors that are on my list are the:
Sony VPL-VW40
Sony VPL-VW60 (I know the MSRP isn't under 3 grand, but let's assume I can get it for under 3)
Other things I know for sure:
Dedicated room
Completely light controlled
Room is approx 18.5 x 13.5 x 8.75
Projector will most likely be on ceiling (although I could probably put it on a shelf in the back)
I'm planning on 16x9 even though I woulod love to do 2.35:1. I'm just not sure I want to spend the extra money for the lens. It would be great if the Projector could do it though for future use.
I don't want to spend a fortune on the screen so DIY is definately an option
Needs at least 1 HDMI and one VGA (or DVI)
So where do I start? I don't expect for you guys to provide all of my research for me, but what questions should I be asking, and can you provide the model numbers of projectors I should research? Ideal pricepoint is 2000.
Sony VPL-VW40
Dedicated room
