The entrance to my theater is through a wall with 2x6 framing. When I add RSIC and DD, the dimenison will increase approx 2.5". I haven't located any prehung doors with jambs that are that wide without paying mucho dolares for custom work.
1. Is there a relatively easy way to modify door jambs that were intended for 6" walls?
2. Also, what is the best method for extending framing around windows? My existing framing only extends 1/2" from the studs.
3. Should the door jamb and window framing be extended beyond the drywall to account for acoustical treatment?
Cheers,
Matt
Cheers,
Matt
That's really fine work!
