Great Forum!
I'm building a house and will have a Panasonic 1080p Plasma TV hanged above the fireplace. There is only a SINGLE HDMI cable that runs from above the fireplace to an outlet on a sidewall.
The sidewall has surround sound connections, 2 cable outlets, a phone outlet and the said SINGLE HDMI cable. I'm getting a DENON receiver to route the connections through.
I plan on getting COMCAST Triple Play.
QUESTION: HOW DO I SET THIS UP???
With respect to COMCAST. Do I ask for the simple $5/mo upgrade for HDTV???
Can I run the COMCAST cable input to my DENON receiver. Then have my DENON receiver output the HDMI cable to the TV? I understand that I might have to run the COMCAST cable input into a STB or Cable splitter or something in order for the HD signals to work?
I was planning on running my stereo, VCR, TV signal and DVD into the DENON receiver - which in turns runs the signal to my tv above the fireplace via the SINGLE HDMI cable.
Any advice, comments, suggestions would help.
Thanks in advance,
Eric
PS: I'll be living in Arlington, TN - a suburb of Memphis
Thanks in advance,
Eric
