AVS › AVS Forum › HDTV › HDTV Recorders › Firewire & Comcast digital cable boxes
Firewire & Comcast digital cable boxes - Page 6
post #151 of 249
Originally Posted by hondo21 View Post
I successfully captured the entire Super Bowl from NBC (1080i) "live" the other day. I have an iMac and use AVC Video Capture 1.06. When I tested it before the game at first it appeared to freeze and I couldn't get the audio. Then I remembered that I had actually paused earlier and was watching on delay so it was acting just like a DVR recording. When I returned to "live" it worked just fine.
"Live" capture works for me as well, but that's not very useful, if I wanted firewire only for "live" capture I'd save a few bucks a month and get a non DVR HD box.
post #152 of 249
I talked to someone at Corporate, who got in touch with engineering. Told me that 16.57 is scheduled for March roll-out at this point for my area(Lower Bucks-Bensalem) but of course it's subject to change.
But right now, 16.57 is supposed to fix it, and it's supposed to be deployed next month. So we'll see what happens if/when I receive 16.57...
post #153 of 249
Oh, I agree completely. I want to capture programs that I record on my DVR. It's rare that i can have my iMac all set up and start it to record live. I was mainly responding to your post above where you said live recording didn't work for you with 1080i. I have no problems recording live with 720p or 1080i.
post #154 of 249
Well the workaround trick works for me but my issue is now that when I try to transfer programs that were recorded in 1080i the audio is really choppy (almost like it's a throughput issue). Programs that are recorded 720p seem to work just fine. Example: the BCS championship (FOX) can be transfered fine using the workaround. The Superbowl (NBC) audio is extremely choppy using the workaround.
Can anyone give me suggestions on this?
Below is a txt file from an attempted MPEG2repair of a 1080i file.
MPEG2Repair: G:\\090206201110.ts
Sequence Frame 461(20-P) / Time 0:00:15 :
VideoError: Missing 2400 slice macroblocks at MBA=5760(0,768)
Additional error(s) detected. Increase VerboseLogLevel in INI file for details.
FileInfo: Last video errors span 13 bytes at file offset 27437271
Sequence Frame 462(20-P) / Time 0:00:15 :
Info: End of MPEG2 sequence
Sequence Summary:
File Size Processed: 26.17 MB, Play Time: 00h:00m:15s
1920 x 1080, 29.97 fps, 38.71 Mbps (12.72 Mbps Average).
Average Video Quality: 51.42 KB/Frame, 0.20 Bits/Pixel.
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -23.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
1 of 462 video frames found with errors.
0 of 478 audio frames found with errors.
13 corrupted video bytes in file.
0.000000 seconds of video timestamp gaps.
0.000000 seconds of audio timestamp gaps.
End of Log
This is an example of a 720p recorded MPEG2Repair file:
MPEG2Repair: G:\\090206201806.ts
Sequence Frame 1125(2-I) / Time 0:00:18 :
VideoError: Invalid Huffman code in intra MPEG2 block. MBA=2483(48,496)
FileInfo: Last video errors span 37 bytes at file offset 37450691
Sequence Frame 1126(2-I) / Time 0:00:18 :
Sequence Summary:
File Size Processed: 35.72 MB, Play Time: 00h:00m:18s
1280 x 720, 59.94 fps, 38.41 Mbps (14.92 Mbps Average).
Average Video Quality: 30.38 KB/Frame, 0.27 Bits/Pixel.
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 448 kbps.
Dialog Normalization: -25.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: 0.0 dB
1 of 1126 video frames found with errors.
0 of 587 audio frames found with errors.
37 corrupted video bytes in file.
End of Log
post #155 of 249
I have a Motorola DCT 6412 III (firmware 16.53) and just started doing captures. I thought I would NOT be able to capture from the 6412's DVR, but the work around discussed in this thread works for me. I really appreciate the effort of those who provided information on the work around.
I have a couple of questions for those who have received the 16.57 firmware update.
Does 16.57 resolve the problem in 16.53 of not being able to capture from the DVR?
Any new problems present in 16.57?
post #156 of 249
Here's a question whose answer depends on what is actually "broken" with the firmware and how it would affect DVR recordings after a fix is implemented.
If I make a DVR recording now that I can't properly capture via firewire (even with the workaround) because I get no sound, is that recording never going to be any good, or will it be okay later when (if) the firmware gets updated and the fix is implemented? In other words, are existing recordings "good" but the firmware prevents it from transferring correctly via firewire, or were the recordings "corrupted" by the broken firmware in the first place and thus will never be able to be captured?
Trying to decide if I should be patient with a few recordings still on my DVR and try to capture them in the future or if that won't matter.
post #157 of 249
I would imagine that a new firmware fix would make those recordings "capturable" (new word). The recordings are just stored digitally on the hard disk, the outputs on the player output whatever the device is playing back. So a fix to the firewire outputs should "fix" whatever the box is outputting, shouldn't matter if it's live TV or a recording that is 4 months old.
Of course if the recording is 5C enabled, then it wouldn't be able to be captured with CapDVHS. If an old recording is flagged "copy once" and the channel now is set to "copy free" that old recording wouldn't be able to be captured, even though the channel is now copy free. The 5c bits are stored with each recorded program.
post #158 of 249
That's what I assume should be the case too. The programs I'm referring to are "copy freely" - a couple of workout programs my wife likes from FitTV that I want to burn to a DVD sans commercials, plus a movie or two from TCM (stuff that isn't on DVD yet so I want to make my own).
post #159 of 249
If you are doing SD only, it is a WHOLE lot easier just to use a DVD recorder or computer tv tuner/capture card, and use the analog outputs on the box. The only way to get HD off the box in digital form is firewire or HDMI(which is HDCP protected).
post #160 of 249
You assume that because it's SD it doesn't matter. I disagree. Even if the video is SD it is better to capture the digital signal without conversion to analog and then back to digital form.
And no, it's not easier for me to do that way in any case. I don't have a DVD recorder. I don't have a computer tv tuner/capture card, nor could I add one to my iMac easily. I do have a Canopus ADVC110, but capturing the analog video to DV format and converting it from there is a lot more work than using firewire to capture digitally from the box.
I also capture HD (like the entire Super Bowl) from the box. But I also would prefer to get SD content the same way.
post #161 of 249
Any news if there is also a firmware update for the DCH series as well? I have a DCH3416 with firmware 18.43 and can record off of some channels, not others. I can record via firewire from ESPNHD, either live or saved, but can't record CBSHD either live or saved? Some other channels work, like UniversalHD, others like the Big Ten Network do not. I checked CBSHD and 5C encryption doesn't show as active, and the status shows "copy freely" but I get nothing in CapDVHS. Tried the "workaround", no luck.
post #162 of 249
First - thank you all for an educational thread. I am new to trying to capture from my DVR, but am an intermediate level AV geek, so the background is very helpful.
Here's the details on my set up:
PowerBook G4
OSX 10.4.1
DCH341 comcast receiver
using AVCVideo Capture
FireWire SDK 26
I can see the device and it initially shows the device as "open" in the capture software. I create the file, but after saving it, I never get to the dialog box that allows for setting and starting the recording. If I click "Capture" is says it "cannot connect to device".
I've read through thread 1103423 (sorry -to new to post URL's)
which led me to Raj's updated "how to" at
posting 13927293 where I followed his suggestions, but no joy.
Feels like I'm painfully close... painful being the operative word. Any of you pros have advice?
post #163 of 249
I'm having the same issue; the error I get in CapDVHS is "Error: Cannot open output file."
It happens on channels without 5C and on both recordings and live TV. I was able less than a month ago without any issues.
post #164 of 249
Are you sure the file and drive it's trying to write to are valid? I don't get any error like that, it simply doesn't record, no data shows up in the CapDVHS informational fields and there aren't any video/audio PIDs present in the file it creates.
post #165 of 249
For a few months, workaround was fine, as long as I did not want to capture ESPN.
And racing was done, so I didn't care.
But now, the season has started, I have races on my DVR for my son, and lo and behold, video records as a blank screen, although the audio is present, with workaround.
DVR: DCT3416
Firmware: 16.53
Computer: iMac running AVCVideoCap
Channel: Fox HD
Show recorded: 1 week ago.
Anyone else having the same problem?
post #166 of 249
Come on Comcast. We need repaired firmware - roll it out now!
post #167 of 249
Has there been any new information on this topic? I still can't seem to capture anything.
post #168 of 249
Have the 6412 and no workaround works--live TV records fine, but recorded TV does not.
post #169 of 249
Still waiting for Comcast. Something tells me that updating firmware isn't exactly a priority for them.
post #170 of 249
I'm not sure why you are having trouble with the workaround. I have 3 boxes and it works on all 3. Especially on programming that worked live.
post #171 of 249
Can you tell me which post specifically has the "workaround" -- I saw a few--or just quote it for me--would be greatly appreciated and I'll give it another try with results.
post #172 of 249
My apologies--upon re-reading the thread--I realized the file did not work with VideoRedo--it did play fine with vlc media player. I would also note that Pinnacle (12) was able to play the file with audio fine upon using HDTVtoMPEG2 to convert it to MPEG without having to use any repair process.
post #173 of 249
I do have a question--obviously you cannot preserve the High Definition video when converting to MPEG-2, but can you preserve the surround sound audio?
post #174 of 249
The HD stream captured via firewire is already MPEG2, so there's no need to convert it. And you absolutely can keep it in it's original HD resolutions. The AC3 audio is kept intact as well. What I've found is usually necessary is to cut 5-10 frames off the beginning of the file using HDTVtoMPEG, then it's usable by most other apps.
post #175 of 249
Thanks for the input. I found that when I play the video back, I now have black borders on top and bottom. The original program was HDTV (16:9) so I don't know why it doesn't stay in that aspect ratio. Is there some setting I didn't have correct? I recorded using CAPDVHS via firewire and then converted using HDTVtoMPEG.
post #176 of 249
Are you playing it back on a widescreen monitor? If you aren't that's why the black borders are there.
I use VideoRedo for all my ts captures and it works everytime, unless the file at some point stopped recording during the process. This will usually yield a file VideoRedo can't handle. At that point, I just use HDTVtoMPEG to cut the file down to the last frame that did work and then reopen it in VideoRedo.
post #177 of 249
I straightened out the border issue--(yes I do display on WS (Plasma)).
VideoRedo works fine except with a ts file recorded with the "workaround" you mentioned for recorded shows--I have to used HDTVtoMPEG and then it works fine.
How do you play the movie back in high definition full screen--in other words what media player do you use? Also, if you burn a DVD using VideoRedo, will it burn it in high definition and surround sound (I have a Panny Blu-Ray Player if that makes a difference)? I am confused about how to get the ts file to play back as it would from the 6412.
post #178 of 249
I use VRD daily to edit recordings off my moto box without issue, thoug have a DCH and dont do any workaround. However if you hit the record button before starting playback of the recording, then the file is uneditable. Record to HDD, then capture later is most reliable versus recording live.
To playback these transport streams on your tv do one of the following:
1. Hookup your PC to your HDTV and use a software player.
2. Get a Popcorn Hour or Tvix, connect to to your HDTV, then stream the file from your PC.
3. Burn as a Data DVD and playback on a device like mentioned in 2.
(Dont convert it to a Video DVD as this would severly reduce the resolution and take a long time)
Likely the Panny will not playback HD Mpeg2 on DVD's.
post #179 of 249
VideoRedo doesn't have the ability to burn DVDs. If you want to watch them in HD, you need authoring software that can burn Blu-Ray discs (and a Blu-Ray burner of course!) like PowerDVD, Nero, etc. It is possible to make an AVCHD disc on regular DVDs that some players will be able to play back, not sure if the Panny can or not. Can't help too much there as all I have is an HTPC and a PopcornHour A100.
post #180 of 249
Get the PopcornHour. It does a great job. The Mvix will play some HD but not .x264 which many, if not all .mkv files are. The Mvix is good for playing regular DVD ISO files. I have both. I like the Mvix for playing DVD ISO files especially since it has the sleep function so it's good in the bedroom. All HD files are played on the PH. The PH has a lot of good features, read here http://www.networkedmediatank.com/wi....php/Main_Page
Forget about burning to disk, set up a networked storage.
  Back to Forum: HDTV Recorders
