Originally Posted by
ralnraln
Hey guys
I can't seem to successfully open/record Recorded recordings on my Motorola DVR (DCT 3412 Phase III) using AVCVideoCap - I can do live shows but I can't get recorded recordings.. which is what I need
Any help Anyone?
There was a bug ~ 5 years ago that caused those Motorola DVR's to behave this way...live TV could be FireWire captured, but DVR recordings could not. It's been quite a while since that was an issue, so I highly doubt that it's the cause of your problem. I think qz3fwd is on the right track...your recordings may be protected and therefore not allowed to be FireWire captured. If they are from premium channels such as HBO or Showtime, they are guaranteed to be protected (those companies now require the cable companies to protect those channels and they will pull their channels from cable companies that fail to do so.)
Also, if you are on Time Warner cable, basically every channel is protected and can therefore not be FireWire captured (the Over-The-Air broadcast channels are not protected, but most cable channels are.) If you are on Comcast, most channels can be FireWire captured except for the premium channels and the on-demand channels.
If you can provide more information about your setup/cable company, we may be able to narrow in on the issue. One alternative to FireWire captures is to use a device such as a Hauppauge HD-PVR (or Colossus) or the Black Magic Intensity Pro.
