Originally Posted by DigiDummy
I got a Zenith DTT901 at Kmart in Costa Mesa, CA today. $49.99 minus the $40 coupon. They had quite a few but even more of a Magnavox model.
I hooked it up and went through the set-up process, and am getting "No Signal" on any channel. Relying on analog reception, this same TV picks up three or four channels rather fuzzily. Should I be concerned that perhaps the antenna jack on the new box doesn't work, or are the digital broadcast signals not operating at full power yet? To not even get a weak signal on one or two channels scares me. Any answers/advice would be appreciated. Thanks.
The previous reply includes most of what I was going to say. What kind of antenna are you using right now? And do you live someplace where there's something (tall building, big trees) very close to you that might be making the signal harder to receive? That can be a factor, but don't know if it'd be enough to be completely 'no signal' as you currently have. If you do have that kind of issue, you probably will need a really good antenna. If it's not an antenna problem, then sounds like a defective unit (haven't heard of many, but it does happen). The Zenith definitely has a far better reputation than the Magnavox, though, so no need to fear you bought the wrong brand!
Best of luck & looking forward to hearing how it's going.
