Well, since the remote came out in Sept. 2004, and the LG LSS-3200A DirecTV receiver came out in Dec. 2003, and the DTT-900/901 can be controlled using an LG DirecTV receiver code, I'd say you have a shot.
I can't seem to find any older, LG DirecTV models, but if the 3200A came out a year later, the remote *could* be updated with that code. No guarantees, though.
It isn't an actual "LG"-labeled remote, and I know that it wasn't manufactured specifically for Zenith only, because I've seen it under at least one, other brand name (Philips, maybe? - so it might've been made by whoever manufactures Gemini). Maybe you could try to find out who actually manufactured the remote (might even say it on the back of the package), and call and ask them if it specifically has a code which will control the LG 3200A.
How much does the store want for the remote? I see that it's available new through Amazon for $30.
(edit: I just looked up the remote's manual online, and was able to check the code list. Unfortunately, there's nothing under "satellite" (cable, either) labeled "LG" under it. Nothing uder "Goldstar", either. But there are plenty of Zenith and Hughes codes. Up to you if you want to take a chance. Goldstar did acquire Zenith to form LG all the way back in 1995, so you might want to take that into account - although I don't know if it would necessarily mean anything. If anything, being the owners of both, I would figure they'd probably be more inclined to distinctly separate the brand names in the listings than anyone else. Actually, there doesn't seem to be any codes listed there under "LG", now that I look over the whole list closer.)
(believe the Tube isn't firing up)
