Originally Posted by
Floydage
I was able to reset all the channels back to Cropped (my fav) in the menu but it was kinda weird to get it to stick for all channels. I had to try it on a few of the channels I experimented with. It might have been the one I had Set By Program that did the trick. No detail in the manual on this. I was also using the Ratio button on the remote to set each channel indepently. Now this is an Artec but I suspect similar to Zenith.
Hmmmm, maybe reformatted for modern use? (Seinfeld).
Based on medical costs it would probably be worth paying for help moving these heavy TVs if free help is unavaliable.
The main channel is usually settable & sticks, though the ratio on the subs cannot be changed (at least in my area). I liked the cropped setting too with the 4:3 sets. Once you remove the channel & add it will have to be reset again though.
I live on the 'Angry' planet, free help isn't available. (with the price of gas too, who can blame anyone for not wanting to go out of their way anymore).
Since I had to sell my van a few years back I haven't been able to haul anything sizeable, come to think of it I may not even have a vehicle to properly bring home a 42 flat screen.
Yeah you can pay the geek squad $150 to come out & haul it away, I guess that would be worth it.
Floydage
Wow that's some loaded 20" TV, even component inputs and does 480i. Nice locale luck too, I see good deals too but too far away in this big ol' metroplex.
My Technics 5 disk turntable CD player starts like it will play a disk but then goes onto the next disk as if there's no disk in the slot and this repeats all the way around regardless of slot. I hadn't turned it on in a while before this started. It has a dust cover but could a dirty lens be the culprit?
A lense cleaning is where I would start, even in a non smoking environment these lenses apparently get a film, I have had several skip & freeze CD & DVD machines instantly cured with just a swipe of alcohol across the laser lense.
The manufactures continue to try to bury this lense too to make it inacessable.
That Samsung 20" is a sweet package!
