That was our worry getting it off the dolly it was crumbling, I grabbed the area under the speaker which broke off in my hand (along with the speaker itself)... the cabinet chards were more dangerous... no way it was going to be moved as a complete set at that point.
Before it went into the car we removed the CRT which was easily moved with 2 people
Still have the 20" flat Philps CRT & I temporarily brought down the 12" RCA Black & White for the few days I was waiting to pick up the LCD. the 37" still was akward, though I was able to move it from the car to the house by myself, I'm thinking I wouldn't want any if much bigger.
They have 5 Subs, including a Childrens oriented channel, a Hispanic channel, & JCTV, though since they are putting up highway sound barriers nearby, or the station has reoritented it's pattern, which was a 80-90% catch is now only a 40-50% catch, I no longer program it into the boxes. The have a LP repeater in Cleveland on Ch 7 which is pointless since WDLI's main signal covers the entire area where the repeater is anyway. Occasionally I would watch a movie on there.
I was going to ask that, since I still use the 901 as a aux tuner for the VCR (via the RCA outputs on the 901, I record on the AUX channel on the VCR since the analog tuner in the VCR is shot anyway).. I also route it to the TV via series & am able to watch it via analog channel 4 on the set. Would I be better off using a splitter at the set or just leaving it the way it is? (in series with the TV)... or a A/B switch as you mentioned?
Originally Posted by Floydage
Maybe a better u-remote would give you all the required functions? Then the money would be applied to something useful down the road. I only bought the Panny TV remote because of unique aspect, PoutP, etc. functions.
Some of these sellers sell TVs without remotes and then sell the remotes at a later date. I can usually find instructions on the 'net.
I have a couple of RCA RCR815's I picked up at my closeout store for $2.99 ea they are fully backlit & have a learning function.... though I have one dedicated to the bedroom setup, & use the other for testing purposes, they come to as close to being a complete remote than anything else I have, though they aren't new enough to cover the Zenith boxes or the new TV.
In my case it may have actually worked out to my advantage as I have a severe allergy to juniper (aka mountain cedar misnomer here). More of a winter allergy. I can get extremely sick from too much exposure and has caused me to go to the doc for antibiotics (sinus/bronch infection). The good news is I can 'hole up' in the winter, the bad news is it's Texas (i.e. oftentimes nice days in the winter to be outside).
Hope it isn't kicking your butt too bad this spring.
"yeah, I'm still here"
Been sick this spring myself, though it was a relief not to be inhaling the road chemical residue this year, I noted it kept my BP in check somewhat this winter.
. It could also improve performance to terminate the unused amp output ports (although a long cable still hooked up to the amp, even if open at the other end, can act as a sufficient load due to the loss of the long cable).
; too bad they didn't run anything to the bedrooms (maybe too many splits).
