AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Zenith DTT901
Zenith DTT901 - Page 21
post #601 of 2232
The Zenith DTT901 and Insignia NS-DXA1-APT are the best boxes I have used. I highly recommend either one!
post #602 of 2232
Originally Posted by Digital Rules View Post
Make sure you use a good quality RG-6 cable for connecting the CECB to the TV. The cheap cable that comes in the box is not a good performer on weak analog. I noticed quite a difference when I switched the cable on mine. Just a thought
Got everything working. Thanks for the tip on the RG-6 cable.
post #603 of 2232
I agree; but on a "very weak" analog channel 68; I can see a difference.
Don't worry, next March, there will be no difference.
post #604 of 2232
Originally Posted by nwiser View Post
I was gonna get a couple of RCA boxes b/c 2 of the TV's I have are RCA, making controlling them with 1 remote a lot simpler...however I've heard complaints about the signal meter/tuner strength.
As far as I'm concerned, there are reasons other than technical why I avoid RCA products. Search the 'net for "RCA Armstrong" (no quotes). I'd provide a link, but I haven't made it to three posts yet.
Still, I had considered the RCA for my senior mother because it is easy to understand, but thankfully found the Zenith DTT-901 suited her needs. It gets great reception 20 miles from the Oklahoma City towers and channel changes are surprisingly fast using the old Radio Shack attic antenna she and I put up a long, long time ago. The cable used is not even coax - it's that broad, flat antenna wire. I went and bought a DTT-901 for myself the next day and use it with rabbit ears. Channel changes aren't as fast as at Mom's, but I get the station(s) I need (PBS). Hooked it up with both RF and composite connections, and some visual elements look better with the composite and some better with the RF. Odd...
-katapaltes
post #605 of 2232
Originally Posted by 300ohm View Post
Hmmm, so you think theyre gold plating the entire center wire. I dont think so, heh. Plus the center pin is machined slightly where it attaches to the plastic. It has to be soldered/connected on the inside to the copper cable, which is worse than having it go straight thru.
300ohm. I guess I didn't read your prior post adequately. You did mention a gold-plated connector. The OP was asking about his DTT901 and I was pretty sure my DTT901 came with a cheap, thin cable. I had to go dig out the cardboard box that still housed the cheap cable to confirm that it came with a cheap, thin, cable with non-gold-plated connectors. It sure looks to me like the pin on this cable is the steel center conductor and isn't even copper clad, let alone gold.
Are you saying that some manufacturers actually attach a "pin" to the center conductor of factory produced F connectors? I'm not saying it's not possible, hence my use of the word "usually", just not what I've seen.
post #606 of 2232
"Are you saying that some manufacturers actually attach a "pin" to the center conductor of factory produced F connectors?"
That is absolutely correct in my experience.
post #607 of 2232
That's interesting. It seems counterintuitive to me to create some boundary, whether mechanically attached or soldered, between the center conductor and the "pins". I would think it would be more practical to do just as 300ohm suggested and just gold plate the ends of the center conductor where they are exposed to the elements, but just gold plating the ends of the conductor would also create a boundary, so I'll leave it to the engineers to say which would be better.
I've been googling around to try to find an F-connector with a pin for the center conductor. My first stop was at wiki which discusses the invention of the F connector:
[quote from wiki] The F connector is inexpensive, yet has good 75-ohm impedance match up to 1 GHz and has usable bandwidth up to several GHz. One reason for its low cost is that it uses the solid conductor (center wire) of the specified types of coaxial cable as the pin of the male connector. [end quote]
But, here is a Canare with a gold center pin:
post #608 of 2232
Some expensive RG-6 F-connectors have a pin; I don't know if this is for durability or weatherproofing or just an excuse to charge more. RG-11 F-connectors have a pin, because RG-11's wire is too thick to be used as the center.
post #609 of 2232
I agree. It's probably a marketing gimick so that they can brag about gold connectors and therefore charge more.
post #610 of 2232
Interesting sight at the Circuit City near Belden Village Mall (North Canton, OH) yesterday.
They have a bunch of Zenith boxes, almost all DTT901's with a June 2008 date on the side.
They still have about a half-dozen DTT900's stacked next to the 901's, with an April 2008 date.
Over at my local Best Buy up here, their stock of the Insignia is all APT versions, now. I can't remember the date, but I believe June 2008 there, too.
post #611 of 2232
To keep this on topic I have 2 April-build DTT901s. One replaced the DT900. I'm in central/north NJ and have problems getting some stations and others loosing signal and I know there can be many reasons for this as outlined on the NY OTA thread.
I went to monoprice to look for a good quality RG-6 cable as Digital Rules suggests. Forgive my ignorance, but monoprice offers (at least) 2 types. Product 2680 is 6ft High-quality Coaxial Audio/Video RCA CL2 Rated Cable - RG6/U 75ohm (for S/PDIF, Digital Coax, Subwoofer & Composite Video). I think the center pin is too big for the RF input/output connections. Product 3031 is RG6 F Type Quad Shielded Coaxial 18AWG CL2 Rated 75Ohm Cable. This one's pin looks like a better fit.
Beyond the build quality of the 2680 RG6 cable, is there a difference? Am i missing something?
post #612 of 2232
The 3031 is what you need for antenna connection.
post #613 of 2232
The only difference between the two are the brand names, the owners manuals are formatted differently and the Zenith has a one year warranty whereas the Insignia has a ninety day warranty.
post #614 of 2232
Thanks arxaw. Just ordered that 3031, a couple of HDMI cables and some misc items. My first order w/ monoprice. I cannot beleive the pricing.
post #615 of 2232
Originally Posted by DigaDo View Post
The only difference between the two (is) the Zenith has a one year warranty whereas the Insignia has a ninety day warranty.
Big difference there.
post #616 of 2232
Two years ago fter getting a raise to nearly $50 a month for cable I went to OTA. Now after studying these columns I went digital with the DTT901 and am very satisfied. It was quick to set up and with the sub bands I get more and better stations than with analog. The remote is laid out better than any of my regular TV remotes - volume, channel and power are well separated and easy to tell apart. There are not a whole lot of buttons - that is a good thing. It also works power and volume on the TV, so the TV remote can stay in the drawer. The menu could use some streamlining, but once things settle down that should not be an issue. Nervousness over reception originally inclined me to a CM-7000, but the DTT901 was on hand at hhGregg and reception has not been a problem after all. It is easy to turn the box off and look at the old analog signals, but in my area there is no reason to bother. So thumbs up
post #617 of 2232
Basic features: ........................... DTVPal ............. Zenith DTT901
Analog pass through ........................ Y......................... Y
Closed Caption ............................... Y (On/Off) ............ Y (Toggles all selections)
Controls on Box .............................. N.......................... Y (Power and Channel up/down)
Event timers .................................. Y..(5).................... N
Inactivity timer ............................... Y..(4-8 Hr.)............ Y (1-4 Hr.) (Note: Or deactivate on both brands.)
On-screen program Guide .................. Y..(up to 7 day).. simple guide (Now/Next)
Parental Controls ............................. Y......................... Y
Program Browse .............................. Y......................... N Note: DTT901 - You can browse channels in the simple guide.
Program search ............................... Y......................... N
SAP .............................................. Y......................... Y
Set Up Wizard ................................ Y......................... Y
Sleep Timer .................................... N......................... Y (1-4 Hr. isn't really a sleep timer. See test)
TV Guide OS, Guide+ mode ................ Y......................... N
User Guide (Printed) ......................... Y......................... Y Note: DTVPal user guide has a more detailed alphabetical index.
Tuner features: ........................... DTVPal .............. Zenith DTT901
Auto tuning (set up) ........................ Y.......................... Y
Add or Delete Channels .................... Y.......................... Y
Manual Tuning ................................ Y.......................... Y
Scan to Add new channels ................ Y.......................... Y
Remote basic features: ................ DTVPal (1.5 NDB). Zenith DTT901
Analog pass through ........................ Y.......................... Y (Power button only) (DTVPal has APT button or use power button)
Closed caption ................................ Y.......................... Y
Guide ............................................ Y.......................... Y
Digital tuner volume ......................... Y.......................... Y
Favorite Channels ............................ N.......................... Y
Mute ............................................. Y.......................... Y
Picture Format ................................ Y.......................... Y
Power on TV ................................... N.......................... Y
Program Description ......................... Y.......................... Y
Program title info ............................. Y.......................... Y
Recall last channel ........................... Y.......................... Y
SAP ............................................... N.......................... Y
Signal strength ................................ Y.......................... Y
Sleep Timer .................................... N........................... Y
TV Volume ...................................... N........................... N
Note: Some buttons on each brands remote use different names, but have the same function.
Miscellaneous:
APT works when unplugged ............... N........................... Y
Boot time after unplugged ................ 50 second................ 5 sec. (Note: Includes 25 sec. program guide update on the DTVPal) after powering on.
Powers on after unplugged ................ N........................... N ..... (Note: Both brands will be powered off after a power disruption.)
Power supply ............................... External................. Internal ..(Note: DTVPal wall wart is less than 1.25 wide. Occupies one power strip outlet.)
RCA composite (out) in APT .............. N/A ....................... N/A
Size (approximate in inches)
DTVPal - 5.87 W, 4.25 D, 1.25 H
Zenith DTT901 - 8.4 W, 6.5 D, 1.55 H
Beeper
Specifications subject to change. Not responsible for errors or omissions.
post #618 of 2232
Head to head comparison between the Zenith DTT901 vs. DISH's DTVPal digital tuners.
The Zenith being popular because of it's wide local availability and reputation,
faces the DTVPal with it's excellent program guide and being the only CECB currently having event timers.
Your results may vary depending on your antenna system and geographical location.
I tested with two TVs. One newer Panasonic 27" and a mid 80s Mitsubishi 25". I tested with both rooftop and rabbit ear antennas.
I am not in a fringe area. I am close to an antenna farm in flat terrain. (I did do testing at a later date 40 to 50 miles from the towers)
The Zenith DTT901 is a June 2008 build. The DTVPal's tested were F100, F101 and F103 firmware versions.
First impressions:
Both brand units are packaged well. The Zenith does include the RCA composite cables, the DTVPal doesn't.
The Zenith remote is cheap looking, being thinner and squared off. The DTVPal remote uses two batteries, the Zenith's remote uses one.
The boxes themselves are just the opposite. The Zenith box is metal and has a quality look, while the DTVPal box is plastic and cheap looking.
The DTVPal has a small green power indicator light. The Zenith has a large red light when off, that turns to blue when on.
The DTVPal does have an external power supply at the end of the power cord where it plugs into the outlet, allowing the box to be much smaller in size.
Initial setup was easy and fast for both brands. Initial channel scans took about one minute for each unit to find 24 channels.
Running temperature for both boxes was very low. The DTVPal will stay slightly warm when powered off, as it does maintenance. (No vent holes)
Now for the main things that concern most shoppers. Picture, sound quality and reception.
Picture Quality:
The average viewer not doing a side by side comparison, may have a hard time distinguishing much difference in picture quality depending on the TV input used. When viewed through the RF (coax) connection the DTVPal generally looks very similar to the TV's built in analog tuner. During SD source broadcasts the picture looks slightly less clear compared to my TV's tuner. During HD source broadcasts, the DTVPal's picture quality is noticeably sharper. The DTVPal does show some echoed shadows noticeable behind text and some dot crawl like flickering around text.
The Zenith when viewed through the RF connection generally looks like a better picture. It is definately a slightly sharper focus compared to the DTVPal and has less shadow and flickering behind text. There are however two reasons the Zenith picture generally looks, what some might consider better.
The color saturation is a little on the high side and the brightness is on the low side. So much so, that it hides some details in shadows. Both of those things can be adjusted on your TV to bring them inline with your preference. Same for the DTVPal, you may want to bring up the color a little, drop the brightness and give it a little more sharpness. If you made those adjustments on both, the Zenith PQ would still be very slightly better viewing up close.
The DTVPal when viewed through the RCA composite connection looses a slight bit of color saturation and gains sharpness.
(Typical for this type of connection.) This connection eliminated most of the echoed shadows behind text in the DTVPal.
The Zenith when viewed through the RCA composite connection looses a lot more color compared to the DTVPal. That brings it's picture quality more in line with the DTVPal in a side by side comparison. Again, the Zenith being very slightly better overall. Screen flicker was seemingly the same for both brands.
One complaint from users of various digital tuners is that a "Cropped or Zoomed" HD source picture is shifted from it's analog counterpart. That is the case with both brands tested. The DTVPal being the worst offender with the picture shifted about 1/4 inch to the left on a 25 inch screen, and the Zenith about 1/8 inch to the left. The letterboxing on the Zenith seems accurate compared to an HDTV, while the DTVPal has more real estate of viewable picture top and bottom when letterboxed. A whopping 7/16 of an inch at the top and 1/4 of an inch at the bottom on a 25" TV. The black masks are in the wrong places. This may be the cause of some VBI in the picture when viewing "postage stamped" format 4:3. Something I don't generally do except during testing.
Sound Quality:
As for sound quality, both are very good and no noticeable irregularities were heard. Both brands were also tested while being connected to an A/V control amplifier. The sound issues of Zenith's 900 were addressed in this update of that model.
Using the DTVPal through the RF (coax) produces a lower volume than the TV's built in analog tuner. (To low in my opinion.) The DTVPal's volume through the RCA composite connection is noticeably louder and seems more correct compared to my TV's analog tuner volume.
The Zenith's sound volume through the RF (coax) connection is much louder than the DTVPal's. Through the Zenith's RCA composite connection the volume was also tested by me to be louder than other similar audio video devices connected to an amplifier. The Zenith's internal volume was set at 85% to match the same analog channel on my TV's tuner.
In both units, the RF (coax) connection is mono and combines the right and left channels. If you have a mono TV with RCA composite in, choose "mono" in the audio setup. That will combine the right and left channels in the audio RCA output. If you hook up the RCA audio out to any stereo device, select "stereo" in the audio setup. Some Zenith users have noticed little difference when switching between mono and stereo using a stereo TV.
Using headphones, my unit did obviously give mono and stereo.
Remote control conflicts:
Both brands had remote control conflicts in my situation. The DTVPal remote conflicts with certain model DISH satellite receivers. The satellite receiver remote can have the address code changed. That cures only half of the problem. A replacement remote is being issued by DISH to cure that issue.
The following link describes the fix: http://www.avsforum.com/avs-vb/showt...5#post14729255
That fix actually gives a far superior multi-function remote, not available on other CECBs, similar to using an after market universal remote.
The Zenith remote will conflict with other Zenith / LG receivers. For example, it conflicts with my LG LST-3510A HDTV receiver.
I did have a problem with the Zenith remote (Power button only) being sluggish when the unit was behind glass.
The DTVPal remote didn't have that problem and never failed to connect, even when not aimed precisely.
Program Guide:
The extended program guide (up to 7 days depending on your local stations) in the DTVPal places it way ahead of any other CECB on the market.
If you are familiar with using the program guides that satellite services provide, then you will appreciate the DTVPal's guide. If you intend on connecting a CECB to a recording device for multiple events, the DTVPal provides up to five timers that change channels. Those people wanting to continue using guide services such as TV Guide On Screen and Guide Plus, can configure those services to work through the DTVPal.
The Zenith's simple guide shows you what you are currently watching and the next event. You can move through the channels in the simple guide to see what is on other channels and tune to another channel from within the guide.
If the DTVPal's program guide and timers don't excite you, then both brands have very similar features, with only slight differences in exactly how you can use the tuner. The Zenith may be easier in some aspects of set up and tuning channels.
Signal strength:
The first thing to do if signal strength upstream of the tuner is a concern, is to discard the Zenith supplied quick connect RF connector and use screw on RG 59 or RG 6 coax. You loose about 10 percent signal strength with the Zenith RF cable.
I tested with a rooftop antenna, and with rabbit ears so I could see the results of a weaker signal.
With the rooftop antenna both brands tuned in all of the stations in my area and continued to receive them. I didn't find much difference between the two in signal strength at my fairly close distance to the towers. Both fluctuated in signal strength more so than I would have thought at my proximity. With the rabbit ears the signal strength was witnessed to be considerably lower. Both brands continued to seemingly have similar signal strength and I had one low power station that would come and go in both. At a greater distance from the towers, you may notice more difference between the two brands.
Both brands have a quick way to check the signal strength from the remote, as well as signal strength shown when manually tuning. The DTVPal signal strength appears with the program title banner and quickly disappears. Using the browse button, keeps the signal strength meter visible longer. The Zenith signal strength meter will disappear after one minute if you allow it to. The Zenith also an audible beep that speeds up with a higher signal so you will know how you are affecting the signal without seeing the meter.
Update. Tested reception from two sources at a distance of 40 miles and (50 miles antenna backside), with rooftop antenna. Somewhat flat terrian without structural obstructions.
First of all your results may vary considerably, depending on your terrain and more importantly, the quality of your antenna system.
Your antenna system also includes mast mounted pre-amps and the length and quality of the wiring.
I have not had any success with older mast mounted pre-amps used with digital tuners. In fact, they seemed to weaken the signal strength on all channels and block certain channels from obtaining any signal at all. It seems as though some channel's signal does not make it throught the pre-amp circuits, even though they are moderately strong signals without the pre-amp installed. Both pre-amps tested were old and not advertised as being compatible with digital broadcast.
Secondly, a UHF only antenna gave the strongest signal even on the "VHF Hi" frequency channel 8, because it is not loosing any dB by being connected to VHF elements. You can check your particular area at www.TVfool.com for the actual broadcast frequency existing now, and for changes after the transition. Most are in the UHF band.
If your antenna system is not ideal, the Zenith may be a slightly better choice, as far as locking some stations. The DTVPal on a marginal antenna system exibits more fluctuation in the signal and some marginal channels may not be watchable. However, with an efficient antenna system, the DTVPal signal strength became slightly more stable and higher than the Zenith. Both brands pulled in all of the stations from a city 40 miles away and a couple from another city 50 miles away on the backside of a UHF only antenna. The pre-amp went into storage.
Warranty:
Zenith 90 days labor / one year parts. With problems after 90 days, you might as well trash it. Shipping and labor would be more than a new box.
DTVPal 90 days parts and labor.
Note:
If you have these on a power strip that gets turned off regularly, the DTVPal needs more time to boot and then update the guide before it can be viewed.
Features comparison.
Guide:
The DTVPal program guide data is saved. The Zenith looses guide data when turned off. Has guide data only for current channel when turned on.
You must tune to any of the other channels to load the guide data for that channel before it becomes available in the simple guide.
DTVPal - Guide layout looks like a printed TV guide or satellite guide. You can set timers, tune channels and access current and future program descriptions while anywhere in the program guide. You can access a program description while using browse and viewing the current channel.
Zenith - Simple guide shows currently tuned channel "Now/Next" only. You can tune channels from the guide. Allows access to current program description only. When in the guide, you must tune to another channel to see another channel's program description, resulting in your leaving the guide. While in the Zenith's simple guide, you can browse other channels while seeing some of the picture and hearing the sound.
Aspect ratio:
Both effectively give the same modes. The Zenith has an additional choice of "Letterbox" that appears to be the same as the "Set by program" mode.
Zenith - Remembers picture format (aspect ratio) for each channel.
DTVPal - Picture format retains the last used setting for all channels, but does automatically give a full screen 4:3 picture for SD channels.
Remote control notes:
Zenith has a favorites list button. Although with a program guide, channel surfing is more effective in the guide where you can see the program titles.
Zenith has a programmable TV power button to control your TV. This I would use regularly.
Zenith has a convenient method of selecting sub-channels from a dropdown list after first inputting the main channel number. This I would use regularly.
Zenith has a sleep timer on the remote. The box will turn off, but your TV will not. I found that all the sleep timer does is adjust the inactivity timer.
If you set the so called sleep timer for 1 hour and it shuts off the box, the next time you use the box, it will still be set to shut off in 1 hour.
Zenith has an SAP (alternate audio) button on the remote. The DTVPal SAP selection has to be accessed from the menu.
DTVPal has an analog pass though button on the remote. Although it is faster to just turn off the unit to get pass through, like the Zenith.
DTVPal allows browsing other channels titles and descriptions while watching the currently tuned channel.
Somewhat the same in the Zenith guide, but you can't access other program descriptions.
DTVPal allows searching the guide for program titles and descriptions and saving search results.
Closed caption:
Both brands have similar customizable closed caption function.
Conclusion:
Both brands were easy to understand and use. The DTVPal printed user manual did have a better alphabetized index for finding page numbers in the manual. Both brands performed as expected during my testing.
Once I had both setup the way that I would use them and stop playing with them, there wasn't much difference in actual usage for me.
I do use the extended guide a lot, so I missed not having that on the Zenith.
When using the DTVPal, I would have used a TV power button if available on the same remote.
For the average person not doing much recording and having a printed TV guide, the Zenith would be a good choice. Although most printed TV guides don't currently have listings for sub-channels, the DTVPal guide would have a greater amount of those listings available.
I tested the DTVPal's event timers, and they worked correctly for me, as long as each channel's PSIP clock time was close to being accurate.
The DTVPal currently has some issues with the timers for users in some areas. One of which is related to some station's PSIP clock time being inaccurate. And another, related to getting an abnormal guide download at power on that affects set timers. The F103 firmware has fixed the later issue.
Incorrect PSIP time from your local stations will affect the accuracy of the program info in the Zenith as well.
Beeper
post #619 of 2232
Remote basic features: DTVPal Zenith DTT901
Analog pass through Y N
That should be a "Y" for the DTT901
post #620 of 2232
Beeper, do you always lose guide info on the Zenith? I don't. I have had it off for 3 hours and it has come on with guide info -- sometimes, not always, and I haven't figured out what keeps it or loses it.
Another good feature of the Zenith is that you can surf for programming during the commercial and know exactly when it's time to return to your show. And if you want to finish surfing first, you get audio and partial picture, so you don't miss much. I use that feature a lot. The display/program info I get is also much more detailed than anybody's picture of the Pal, although that may be regional difference.
Dave Zatz said the Pal's cc button is on/off. That means you can switch between your preferred setting and off very quickly, leaving the font detail to the menu. With the Zenith you have to go through a lot of cc options to turn cc off.
Thanks for the great detailed comparison!!
post #621 of 2232
You mean because the power button is on the remote?
post #622 of 2232
I loose the guide data on the Zenith when I turn it off.
When I turn it on, it gets the guide data for the channel currently tuned,
but all the rest show "no information" if you go directly to the guide. That's how mine is working.
post #623 of 2232
No, I mean Yes it has analog pass through.
post #624 of 2232
[b]For the average person not doing much recording and having a printed TV guide, the Zenith would be a good choice. Although most printed TV guides don't currently have listings for sub-channels,
Use a Cellphone, Palmpilot, or other internet device to access zap2it.com or tvguide.com as they offer 2 weeks worth of subchannel programming.
post #625 of 2232
I sometimes use Zap2it myself, but grandma doesn't have access to any of the above mentioned services, which was my point.
post #626 of 2232
Beeper,
Did I read that features comparison correctly that the DTVPal has an external power brick instead of an internal power supply? That's a deal killer for many of us that are just fed up with all the power bricks we have to find a place to plug in; usually means another power strip or extension cord.
CEBII
post #627 of 2232
Does the Zenith DTT901 allow direct tuning of the subchannels without a special character like a dash?
For example to tune my CW station, I would type '272' on the remote.
Is that how it would work on this box?
I need to know quickly (expiring $40 coupon in 2 days) for using one with my Series 1 TiVo, which TiVo stated they will not support for less than $399 and would exclude the use of my satellite dish receiver from their offer (HDTivo which has no satellite ability).
My series 1 TiVo is hacked and I want to capitalize on the channel mapping feature to map subchannels to other guide channels, but I need a CECB that is
1) able to be controlled by the TiVo's remote zapper with remote codes already existing in the TiVo
2) capable of direct tuning subchannels with ONLY a series of numbers (no dash or special character to tune the subchannel).
I wouldn't think Zenith changed the remote control code from the earlier model, so I think the DTT901 is still fair game, but I just wanted verification from a current DTT901 owner on how channels are tuned, so I can proceed with my sinister plan to breath life into the 'old TiVo (since TiVo themselves won't). TIA
post #628 of 2232
Yes, I just did it on my 901. Of course, channels 6 and under dont work that way, being only 2 digits, but 9-1, 8-1, 7-1 do for some reason on my unit. (in other words type 91 and you get 9-1, but 61 which I have goes to my channel 61 not my channel 6-1. Im sure there is some kind of logic to it)
OK, I figured out the logic. If the channel is already stored in memory (the channel list), it will go there. If not stored, then it will go to channel-subchannel. I have channels 61, 51, 41, 31, 21 in my list of channels, but of course not 71, 81, 91 so they go to 7-1, 8-1, 9-1.
post #629 of 2232
I don't have any experience with TiVo but I do have several months with the Zenith remote. It requires very little button pushing. I have never once had to use the "-" to get to a sub-channel with the Zenith remote. I just enter the first number of the virtual channel I want to go to, a menu pops up with all the options and I navigate to the one I want via the arrow buttons. If I want the first listed channel, I don't have to do anything at all - it automagically goes there. I can't see that the "-" is needed at all. Maybe I'm missing something. Or maybe I don't get enough channels for this technique to be problematical.
post #630 of 2232
Wait a minute, I didnt suggest that, at least I didnt mean to, heh. Im pretty sure the whole cable end is a separate gold plated unit that has the center crimped to the RG6 cable. Gold has the advantage that it conducts electricity a little better and it doesnt tarnish as quickly as other metals.
That said, now that I think about it, I dont think the cable Im using was supplied with the unit. I think it may be one I purchased a long time back (no wonder it doesnt look like a cheap cable), heh. I may have instictively used my better cable when I first set up my original Insignia 2 months back. Ill have to look for the Zenith and Insignia boxes (I probably left the cheap cables in it) to double check.
