I'm not sure if this is the right place for this but here goes:
I'm looking to build the ultimate HT system for $50k (that's the speaker budget).
This will be a dedicated theater room and it will be used exclusively for movies.
So far, I've narrowed it down to the following systems:
1) Revel Ultima 2 system (Salon2 + Voice2 + Gem2's)
2) Dali Euphonia system (MS-5's + CS-4 + RS-3's)
3) Aerial Acoustics LR5 system (LR5's + CC5)
4) Klipsch THX Ultra 2 system
5) B&W 800D system (800D + HTM1D + SCMS)
6) Mcintosh XRT1K system
7) Triad Gold system
Which is going to offer the best in-home theater experience? My criterion for good movie sound is the Arclight cinemas in LA, but I believe they use commercial grade JBL speakers.
Are there any other systems or speakers I should consider?
Thanks in advance!
Thanks in advance!
