AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Anyone know the 5-digit Universal Remote code for the OPPO OPDV971H?
post #1 of 6
I'm trying to program my remote control which uses Universal 5-digit codes....to program my Oppo OPDV971H DVD player.
Does anyone know a working 5-digit code? The Oppo site doesn't help with 5-digit remote control codes.... THANKS
post #2 of 6
The newest UEI made directv remotes, the rc64 lists OPPO dvd codes as 20575 & 21525
post #3 of 6
Thanks, but these codes did not work.
The remote I am trying to use is the one that comes with the Toshiba Cinema Rezga RF350 LCD TV by the way.... thanks
post #4 of 6
If your tv manual lists directv codes like 01377 or 01442, then your remote is made by UEI. And your UEI made remote is just too old to have the OPPO codes I listed previously. meaning you're out of luck sorry.
The following UEI made radio shack remotes have OPPO codes and toshiba tv codes: 15-133 on sale now, 15-134, and 15-135.
post #5 of 6
Try these; OPPO firmware version is 05.00.01.07/10-1018B (or 10-1018A or 0910A depending on production run) from 10/02/07. The Toshiba code that worked with my remote for OPPO DV-981HD, 20503 (5 digit) 0503 (4 digit). Other Toshiba codes, 20695, 21045, 21154, 21503, 21769. For 4 digit codes use the ones above but removing the leading "2" so that 20503 becomes 0503. Hope this helps you out.
post #6 of 6
Sorry but it won't, because the OP doesn't want to control the toshiba with Oppo remote. The OP wants to control a Oppo with Toshiba remote.
  Back to Forum: Remote Control Area
