I know there are code issues with running cables through an enclosed wall but I can't seem to find any advice either way when the backside of the wall is open. I'm looking at mounting a flat screen tv on the wall and running cables behind a wall and down into a custom built-in shelf/cabinet that will be on the same wall, the back of which is part of an unfinished area in our basement. It seems like I could just run the cables through a hole in the wall (plan on getting a wall plate/sleeve thingy) down to my components but I thought I'd see if ya'll had any input before I do something that might violate code.
AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Question about running cables through wall
AVS Top Picks
post #2 of 4
5/29/08 at 9:55am
post #3 of 4
5/29/08 at 1:22pm
post #4 of 4
5/29/08 at 1:58pm
AVS Top Picks
Pros:“Excellent value for the price - Paid $79.95 at Frys.”“Absolutely stunning 24p play back. Networked Apps are flawless (wired). Very customizable. Unbelievable DLNA capability. Ability to skip the unskippables in a DVD. Overall professional onscreen GUI. Audio Quality is surprisingly very good. Upscaling as a customizable, menu driven item. Very Apple-esque.”
