It's not a photocell, it's a phototransistor.
Simply it will measure the amount of light coming off the panel over a reasonably small area, say 1" square given the distance I had it at. I sampled at 11kHz and did a spectrum analysis of the resulting data. There were a number of frequency components, but there is an obvious strong peak at the refresh rate. I could see the peak move between 60 Hz and 72 Hz when the PC mode was changed, or if left on Advance when the program material switched between 24p and 60i. I'm sure that the subfield frequency components are there, but I didn't go looking for them. However, my understanding of the Pioneer C.L.E.A.R. driving method would make me think that the frame rate will dominate the spectrum, with the other components (program material changes, dither) being much less significant with my methodology.
My data seems to exactly match what others (including D-Nice) have said about the Elite, so I'm not sure why you think my results are incorrect.
Have you actually looked at this or are you merely hypothesizing without data?
How would you measure the refresh rate?
