[quote=KCinWhitby;16854665]
Very helpful post KCinWhitby, links, instructions and all.
I would add that there is a pretty useful alternate way to approach the calibration of the Non-Elite's 2 Video Mode grayscales of 72Hz and 60Hz ( as opposed to the HDMI PC modes ). That would be to calibrate both refresh rates to 6500K but use different A/V modes as the basis of the calibration.
I describe that a little here.
What I like about that approach is it gives you very distinct looks for flexibility but both calibrated. Using the grayscale calibrated for Movie Mode will still leave with high temp "blue" settings on all your A/V modes.
Using a grayscale calibrated for Standard A/V mode on the other hand will bring the temperature down and much closer to accurate for all the other A/V modes.
A grayscale calibrated for Standard/Performance can also give you a significantly brighter mode than movie mode that is still calibrated. Personally with this setting I no longer feel I'm missing much from not having ISF modes like the Elite models.
For one set and forget mode though I agree, it has to be movie mode and it still looks quite good with almost any source content I can throw at it.
Originally Posted by maglor64
Here is a link to how ot use ControlCal.
http://www.controlcal.com/forum/showthread.php?t=78
At the bottom of POST 2 is a WORD document I started for a more detailed step by step approach for people like me. It is for an older version and ControlCal has been updated since, but it will give you a good idea and TURBE will be able to run you through the rest.
One thing that some people are doing and I think I should have done was to have two different modes calibrated. As an example you could have MOVIE mode calibrated for 72hz and Pure Cinema: Advanced. If you use one INPUT for your Blu-Ray player, you could set it and every time you change it over it is properly set up.
The other mode could be GAME mode with Pure Cinema: OFF. You could calibrate it to a higher temp setting instead of 6500 and get a picture that you may enjoy better for viewing cable television. I find most HD channels to be fantastic in MOVIE at 6500k but for Standard Definition, I prefer something a bit brighter (bluer)
Personally, I calibrated MOVIE in both 60hz and 72hz and I have not had a reason to get out of MOVIE except when viewing SPORTS. I use SPORT mode (which is very blue) for watching Hockey.
You probably won't fully understand ControlCal until you hook it up to your television and follow the instructions. It is really easy once you know how.
Good Luck
Good Luck
