Originally Posted by Coggs
It sounds like there is a 1.5" recess on the back of the panel where the cable inputs are, so even a mount that sits another 1.5" out from the wall should be fine for fitting the cables. The problem is that Pio recommends that their displays have 4" of clearance on all sides. I think a mount like the Peerless ST670 that sticks our 3" from the wall might be a safer bet. It's also rated for 250lb, and is a 3-stud model (instead of 2 like most mounts) so it should definitely hold the weight for a very long time.
-Coggs
-Coggs
This is overkill the 6020 only weighs approx 120lb without the stand. Fastening into two studs will be plenty.
Sanus low profile mounts are good and about 1.5" deep which will be enough clearance. This will also give you an ample 3" of space for the turn radius of the hdmi cable when it's plugged into the awkwardly positioned hdmi ports.
but they dont call it elite or non elite. We get two modells an call them X090/X090H and the differents will be hd tuners and DLNA streaming only in the more expensive tv ( H modell ). ( maby a "pure" mode in settings but that is not sure yet) i have a pre order at the little more expensive modell and i hope i get it in 19-20 june or something.
