AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G non-Elite KURO Owner's Discussion Thread
The Official Pioneer 9G non-Elite KURO Owner's Discussion Thread - Page 272
post #8131 of 14722
Originally Posted by Jeff_DML View Post
did you put the update directory at the base of the USB card, not the long version number directory? also read that PDF closely
I don't know what putting the update directory at the base of the USB card means. The three files from the zip are the only files in the USB. I re-read the PDF and don't think I missed anything. (but who knows with me)
post #8132 of 14722
You need to create a directory on the root of the USB stick called update and move the 3 files into that directory.
Power off the TV
Insert the USB stick
Power on the TV
Cross your fingers
post #8133 of 14722
Originally Posted by Doug Blackburn View Post
I'd be hesitant to update the firmware if I wasn't having bad problems with any of the items listed. There could be other things changed that are not listed... things you may not want in your TV, especially if it has been calibrated with ControlCAL. The firmware could reset the grayscale or do something else that blocks ControlCAL accessing the grayscale controls if you do want the panel calibrated in the future.
I'm not saying these things are in the new firmware... only that they COULD be in the new firmware and changing before knowing if the change is "safe" in regards to being able to have your TV calibrated in the future or to preserve the existing calibration... it would be best to wait until there's an "all clear" (i.e. firmware is fine) from ControlCAL or other trusted source.
I did the Firmware Update and every thing looks the same as before the update. Mine has been calibrated by D-NICE. Also had to format my Flash Drive to "Fat32" before I could get it to work.
post #8134 of 14722
Power off the TV
Power on the TV
Cross your fingers
Got it. I'd like to hear from someone that did the update and was still able to use ControlCal. Doug makes a very good point. I want to make sure it still holds the offsets or that I can get in and set them again.
D-Nice may know the answer to this one.
post #8135 of 14722
Power off the TV
Power on the TV
Cross your fingers
yep and you get to watch some pretty flashing lights
post #8136 of 14722
Originally Posted by Andrmgic View Post
I had heard that the Kuro sets made watching SD content more bearable, but I wouldn't dare compare a fixed pixel display like a plasma to a CRT.
Unfortunately 480i SD will look far worse on an HDTV, even a Kuro, than it will on a good flat screen CRT SD set. I have a 6020 and its HD PQ is peerless. Nevertheless, SD looks about as bad on the 6020 as it does on my other two HDTVs. one a DLP and the other an LCD. It's a function of the garbage in, garbage out principle. The worse the source material is, the more its flaws will be shown by an HDTV.
post #8137 of 14722
Originally Posted by ChicagoPhil View Post
Regarding ControlCal and using D-Nice's offsets, this assumes that all 5020/6020s come off the line within a very close tolerance to a standard, such that these offsets are reasonably accurate for all sets?
Accd to D-Nice the Non-Elites are (were) manufactured to a +/- 5% standard.
Is it accurate to say that the deviation from flat (500 or whatever the number is) that each TV starts at is the factory's adjustment to this tolerance of spec? Whereas the user menu adjustments are all based on a zero'd scale?
I wouldn't think in terms of the RGB number as much as in terms of the electronics hardware. If the hardware deviation and factory settings (whatever they are) only deviate by a small percentage then that implies that the calibrated display values for one set should only deviate (in terms of final result) by a similar range from another set. Thus a good calibration setting for one set produces a reasonable range of results + or - for another set of the same model because of the close QA quality.
Bottom line, it's a free calibration.
Originally Posted by E-A-G-L-E-S
Just easier...
E* = Dish
post #8138 of 14722
I wouldn't think in terms of the RGB number as much as in terms of the electronics hardware. If the hardware deviation and factory settings (whatever they are) only deviate by a small percentage then that implies that the calibrated display values for one set should only deviate (in terms of final result) by a similar range from another set. Thus a good calibration setting for one set produce a reasonable range of results + or - for another set of the same model.
Just seems to me that if each TV can be +/- 5%, then a calibration based on cutting red and adding blue might not work if the TV in question is on the - side of Red already, and the + side of Blue... ??
Dish was formally known as Echostar.
post #8139 of 14722
After decompressing the Downloaded File, I moved the folder "Update" to a Flash Drive. I formatted my Flash Drive to "Fat32". When Re-starting my TV, it took a few seconds before the Firmware update started. It went smoothly. Before this, moving just the 3 files in the "Update" Folder to the Flash Drive and not Formatting the Drive, it would not work.
post #8140 of 14722
I apologize if this is not the proper thread for this post, but I know Buy.com came up recently because of their price on the 6020. I see that they are now Pioneer authorized, so I pulled the trigger on an order today. I'm hoping to gleen some info from those that have bought from Buy.com in the past. I got the e-mail below and it seems like a total BS scam to me. Did any of you past purchasers from Buy.com get this? I can't imagine you really have to go through this. Maybe Buy.com shouldn't be authorized if you are gonna get spammed after using them.
We are anxious to ship your order: XXXXXXX, however we need some additional information to complete the order process.
For added cardholder protection, we are requiring additional verification. To release your order, print out and complete the Buy.com Order Authorization Form located at
(Can't put in the URL since this is my first post, but it takes you to a form to copy your credit card and license and provide some additional info)
Once complete please fax back to (949)389-2827. You will be notified by email when your order is released.
Note: You do not have to place a new order. This order will remain open for approximately one week or until we receive the necessary information.
Sincerely,
Karen Carcano
Address Verification Supervisor
Buy.com
post #8141 of 14722
Sincerely,
Karen Carcano
Buy.com
It certainly sounds fishy.. I would not give them anything...If they can't do it on the phone then it would not get done.. It would be me calling them so I know who I am talking to..
I had to call my Credit Card company and get them to authorize my purchase (6th ave) but it was all above board.. Something here doesn't sound right..
I would be very cautious.. Why would they need a license # ???
Sonny
post #8142 of 14722
Wonder if anyone noticed this... but I've found that SD through HDMI of my cable box looks much nicer than one through 5020's own tuner (RF in). For HD programs cable box output also looks nicer, just with a smaller difference.
Still not sure what gives because both SD and HD channels in my cable are digital so both tuners (in 5020 and cable box) should demodulate the signal to the same bit stream.
post #8143 of 14722
Sonny
Exactly. I'll just watch the other e-mail I got from Buy.com confirming the order and watch status on their website and/or shipping updates. I sure won't photocopy my credit card and license. I'd rather lose the TV purchase than give that info to someone on a fax!
post #8144 of 14722
You may advice them they can contact your CC company for any authorization they may need...
Sonny
post #8145 of 14722
A quick question on my 5020FD... is there a way to display whether the TV is getting a 24p signal? I just switched from a Sony blu-player to a samsung; the Sony indicated when it put out a 24p signal, but I haven't found an informational display on either my AVR or the 5020FD regarding 24p.
post #8146 of 14722
I'm thinking about a 5020 or a 52a750 lcd. Could I just buy the 5020 come home and pop in a blu-ray and watch it with black bars on top and bottom? Or will I get burn in?
post #8147 of 14722
Hey Guys,
I know this isn't the right location for this post, but I didn't have a clue where to ask this question, or I should say make this observation about amazon.com. I've been looking at tv's on amazon.com on a daily basis ever since christmas, and I've been finding a lot of suspicious pricing. If you look right now for instance at the used & new price on the 6020fd and the 5020fd you will see the prices around $1000 under normal amazon prices. The low seller is someone called black sheep deals, and if you check their amazon.com store front you will find lots of other items besides these tv's. Every other item on their sight is so over priced that no one would ever consider buying them but the tv's are dirt cheap. I've already encountered this type thing three times in the past month. Amazon.com doesn't seem to have a good quick way of being notified when someone is trying to run a scam on their site. Has anyone else noticed this ? Sorry if this is in the wrong area, but don't want anyone to get sucked into a scam.
post #8148 of 14722
Originally Posted by webdrifter View Post
Hey Guys,
Amazon does frequently sell through other vendors...Around Christmas it was 6th ave, I bypassed Amazon and bought it straight from 6th ave, saved even more than Amazon was advertising it through them for..
So it is probably for real.. Call Amazon and ask them, they would be who charges you for it...
Sonny
post #8149 of 14722
This topic has been covered many times in this and other threads. Here is just one the many summaries posted here it was posted today;
http://www.avsforum.com/avs-vb/showt...8#post15755528
If a 5020 is something you are really considering, I would strongly recommend that you read the FIRST page of this thread and then the last 10 pages of this thread and there is also a thread for 52a750 owners that can help you too.
post #8150 of 14722
Sonny
This one may be on the up and up but last month I was almost burnt on one that sounded very similar to this one. It was a LN52A650 priced $1000 under amazon's lowest price. I contacted the seller asking about the condition of the tv, and was told it was new never opened. I told them that I didn't see it listed on their store front, they replied they still had a few in stock at that price, and that if I was interested send my name and address, and they would have amazon send me an order for the tv. I sent my name and address, and before long I recieved an order varification that looked to be from the amazon.com website. On the order confirmation it had seller requests payment through money gram. I emailed the seller asking about this money gram thing and they replied that they were an international seller, and that was the only way amazon would allow them to do it. They were actually in italy.
I contacted amazon about this and they said under no circumstance would they or their sellers request a money gram. I'm a little leary now about some of the super low prices even on amazon after encountering this.
post #8151 of 14722
WOW!!!!!!!!!!!What a hose job.... After that I would really be cautious...
Good job spotting it for what it was.. You really should report it to the police or online fraud squad, lol... Whatever, I think it should be reported...
Sonny
post #8152 of 14722
Well D-Nice also has some excellent knowledge of the tendencies of these particular models. So the direction of the errors may follow a fairly predictable pattern for instance.
At the same time a group of shared settings would never be as exacting a good custom professional calibration (unless the calibrator did a poor job not knowing this model well).
We're talking about something that becomes more accurate by the numbers than it was before. You don't have to get perfect accuracy to get significant visual improvement.
Aha, method in the madness. Thx.
post #8153 of 14722
I didn't find any on 5020 either.
But it must be on the BD player information display.
The 5020 will get 24p signal if you set your BD player to 24p (HDMI connection).
But if you are getting the effect of 24p on your screen (smoother movement) or not - is a different story. It depends on Pure Cinema settings (Advanced and Standard - yes, Off and Smooth - no).
post #8154 of 14722
sorry guys i know this has been posted already but my 5020 comes tomorrow and what is ControlCal and D-nice settings for the first 200 hours? Anything else I need to know about the first 200 hours would be helpful thanks!
post #8155 of 14722
After months of waiting I bought the 5020 from an authorized Pioneer online dealer. Now along with a great price they are sending me the monster screen cleaner for free. Now if my memory serves me right I should never use this product on the 5020 due to the coating on the screen. Could someone refresh my memory so I don't end up ruining my panel.
post #8156 of 14722
It has been said the Monster Screen Cleaner has been "known" to damage the Anti-Reflective Coating on the Pioneer Plasmas. We use it everyday on our displays with no ill-effects... but I don't use it on mine. I just make sure to use a high quality micro-fiber cloth and wipe it down every other day or so to keep up on it... YMMV
post #8157 of 14722
Could anyone recommend of a brand of high quality microfiber cloth
post #8158 of 14722
Use the cloth included in the box with the TV..
post #8159 of 14722
Camera store in person or online.
Anything designed to clean high end lenses is more than good enough for this.
post #8160 of 14722
Originally Posted by E-A-G-L-E-S View Post
They haven't been out for two years...not quite one even yet.
But I hear 'ya.
Then I feel even better. After I wrote that I got to thinking....2 years is a long time TV-electronics-wise due to such rapid obsolescence, so <1 year sounds much better to a recent buyer.
