Well Folks the day is here
http://www.samsung.com/us/support/do...p_nm=BD-UP5000
Direct download:
http://org.downloadcenter.samsung.co...AA_RUF_ISO.zip
Hopefully it works out for everyone
Created this thread to report bugs\\fixes for this particular release. BTW thanks to stuartcs for reporting the find 1st.....
EDIT:
To open\\close the PiP 1.1 features (it will show "Bonus View" when available on your TV) press the button Labeled "cursor" on the bottom right hand side of the remote...
Audio:
Bitstreaming:
TrueHD\\DTS-MA\\DD+ confirmed
TrueHD now plays multichannel via all outputs
*For Optical\\Coax users you must set to Bitstream Audiophile or re-encode to get multichannel on some discs
DTS-MA, seems to still only play core DTS track via non HDMI 1.3 connections...
Disc Fixes:
Sunshine
Old Universal titles (tested Mummy) Scene selection now shows pictures....
Memory
**New there are seperate sections for Blu-ray and HD DVD now**
HD DVD memory shows 448 available (up from 128 previously)
Blu-ray is empty, but does not show available space....
Verified Glitches\\Bugs:
There is still "flicker" on disc playback at 24fps (possibly Paramount titles only) This bug was fixed prior to this firmware and has now returned.
Display bug-DTS-MA 5.1 tracks getting dispayed as DTS-MA 7.1....
**The update is now available for direct download via the players ethernet connection****
To burn this to a CD do the following:
Download the Zip file for the update from the link above.
Once downloaded extract the ISO file to your desktop or desired folder
Open you favorite burning software
Select "Burn an Image" (or something similar, different programs use different language)
Once you get prompted for the file, select the Firmware ISO image that you extracted earlier
Burn the CD (in some cases you may want to lower the burn speed to ensure less errors)
Instructions for Mac Users (from user kwindrem):
Download the zip. It should expand automatically and mount to your desktop. Eject the disc image (you don't need it but it doesn't do any harm to leave it mounted either).
Locate the .iso file.
Right click and select Open With ... Disk Utility.
Insert a CD and click on Burn.
You can also use Toast but need to make sure that you select Copy, then Image File on the left side of the window. Then you must select the .iso file.
What setting is best for Me?
We are seeing a lot of questions from memebrs on what audio settings they should use. While some of these settings may not be conclusive, they should point you in the correct direction.
HDMI 1.3 Receiver: Bitstream Audiophile
HDMI 1.1\\1.2 Receiver: PCM
Analog 5.1\\7.1: PCM
SPDIF\\Coax\\Optical: Bitstream Audiophille\\Bitstream Re-encode
If you take a look at this Chart created by Barney_DaPurple1 for the BDP-1400 we are able to at least take a look at what shuold be coming from our outputs )there are differences however):
http://www.avsforum.com/avs-vb/showp...postcount=5800
Direct download:
build date : 2008-05-30 Firmware(US & Canada)
date: May 30. 2008
This Firmware update provides the following benefits:
1. Upgrades current BD-UP5000 to profile 1.1
2. Upgrades BD-UP5000 with HD audio bit-stream output function.
3. Updates User interface based on BD profile 1.1
4. Improves playback compatibility in some movies
date: May 30. 2008
Created this thread to report bugs\\fixes for this particular release. BTW thanks to stuartcs for reporting the find 1st.....EDIT:
Audio:
Bitstreaming:
Disc Fixes:
Sunshine
Memory
). That one played flawlessly on both of my units if I pushed chapter next during the logo.
