Originally Posted by
lalittle
Are you sure it's re-encoding? Ph8te brought up an interesting point that the player could be accessing the hidden DD track in this situation.
Thanks again,
Larry
I am not even sure how to test if it is decoding (internally) and sending the PCM stream via HDMI\\Analogs......
It should however send DD 5.1 via optical no matter what, I believe, if it decodes internally it should send PCM to the receiver when connected via analogs or HDMI, but again not sure on how we would test that......
SOrry I couldnt be of help with the dropouts, I did heard glitches though on JP:III, that are not present now though, so you may be in the clear...
