why can't I teel much difference between speakers that are out of my price range and ones that I can afford. I will say the sound is different but not neccesarily better.
I can't really tell too much difference between JBL,Klipsch, and sony speakers. But I can tell that the klipsch speakers are somewhat more dynamic than the other two but Not much else is different. I can't really tell the JBl bookshelves apart from my 70's phillips bookshelf speakers with the exception tha the JBL's seem to be a bit boomier due the port. The philips are acoustic suspension and I think they can go down to 40 Hz while the JBl's probably don't go down more than 50.
I can't tell polk and companies like that much apart either.
Do I have bad ears?
Do I have bad ears?
I really think if Pulliam ever came close to hearing a high end speaker, his head would explode.
Of course you are
