Originally Posted by
WeThePeople
Common sense said the larger core-to-shield distance would yield better performance at any frequency.
We're getting way off topic here, but there is no common sense that would predict such performance. For a coaxial cable, the diameter of the center conductor and distance between the center conductor and the outer shield (and the type and construction of the dielectric between them) determine the characteristic impedance of the cable. The thickness of the conductors themselves describes the power-handling capability of the cable, which is unimportant for receiver applications with cable lengths less than about 100 feet.
WeThePeople
Larger was the only way for high powered SSB (Single SideBand broadcast),yet the smaller 59 stock yielded better power transfer during transmission of marine VHF plus It's vestigal side bands.
That's a transmission application, and since when is a SSB signal a vestigal sideband?
WeThePeople
But alas for CB and RG-8U, also marine and RG-213 ALWAYS yielded the best reception transfer.
How does a cable know it is transmitting or receiving?
WeThePeople
My point?
For low level RF transfer even the cheapest POC (Piece-O-Crap) wire will do better S-Video if the wire's insulator core is larger. All shielding issues aside. And yes, S-Video qualifies as an RF transfer ! sails way past the 1/2-Mhz line into RF ! (AM Radio is 520-Mhz-...)
Video cables are not transmission lines. In order for a cable to affect "RF" transmission, the cable length needs to at least 1/10 of the wavelength. Otherwise, anything you use is just acting like a straight wire. For video cables shorter than about 15 feet you could use "zip cord" (speaker wire) with RCA connectors on it and it wouldn't be better than the oxygen-free Monster cable.
WeThePeople
And yes Avnstf, It either gets there (at decernable levels of 1/0) or it doesn't. On the topic of purely digital digital transfer it only counts if the wire screws it it up with SWR bounce or refraction delay that fogs the equipment (Can you say heavily condensed internally marine wire?).
What the heck are you talking about? There are no "purely digital" transmissions. Digital codes are always represented by electrical or optical analogs. Standing waves are analog phenomenon.
What is "refraction delay?" "Fogging the equipment" and "heavily condensed internally marine wire?" English, please!
WeThePeople
basicly no,
You aren't provided with the ability to maintain a single coax size properly from unit to unit. The termination connectors are the bottleneck. and at that length the only factore is stem resonance. Ever blow across a coke bottle? That short a length actually introduces a new problem.
You don't need to match coax size for video interconnects in the home. Longer cables need their impedances matched, not sizes. And again, if we're talking video cables we aren't talking about transmission lines. Antenna cables, however,
are transmission lines. Coke bottles only whistle if the volume resonates at an audible frequency.
WeThePeople
But then again yes, the connctors on that cable are a better quality compression type that provide a better shielding ohmic source resistance, and tend too help a touch cancelling problems
"A better shielding ohmic source resistance?" What the heck is that, in English.
