Floyd>>>>>Present and accounted for but me no savvy much of that post. Change the bit rate of a converter box? Or got them to lower the bit rate of the transmitter?
chuck>>>>>the techs lowered the BIT rate at the transmitter on the mountain.....nothing can be done with the box......
Floyd>>>>>OK, hum: See if it hums out of the TV speaker without also being connected to the stereo receiver. Try both coax and composite connections (also, some converter boxes have different menu settings vs. audio hookup).
chuck>>>>>yeah, i will need to try some different things......i was asking if anyone else has had problems like this......this could take a long time....maybe all afternoon.....the anologue siganals are gone.....i need to get a fix on this......i went through the menu.......it works but srill having some problems.....
1....some channels on the video are very good, some ok or not as good.
2....bars of light rolling up the screen then repeat.
3.....audio hummm....some channels hummm is louder than others, some very minimul or not noticable.....as for menu and hookups it is easy to use.....on the back there is antennae in/out for the coax, RCA video out, RCA L/R out for the audio, 3/4 switch for the channel prefered and choice of 3/4 or line out for the RCA video out in the menu.....it does CC, and some other things etc....
Floyd>>>>>Ironically someone near me just posted an ad on CL for a used DS box for $10. Does this box have any special features worth sparking my interest in buying this item? (I see a mention of TVGOS a few posts above).
chuck>>>>i dunno. other than the humm in the audio it functions.... the remote is better than expected.....most universals should work....im using a dollar store remote...it works......
Floyd>>>>In chuck's defense some posters have had lots of problems with this new AVS format including an inoperability of the quoting function. I don't know if it would help everyone but I would suggest deleting all your AVS cookies and starting fresh.
chuck>>>>ok, there is one other thing that could be a problem.....there is a mountain in the way higher than the transmitter.....from what i understand digital signals are directional.....worse than UHF.....using a mast mounted 30 decibal amp adjustable gain with RG6 from the digital ready antennae to the amp behind the TV then RG6 to the antennae in on the back of the DS box, then RCA audio and video out to a VCR or a DVD recorder then audio out to the analogue stereo receiver so i can record something if i want.....i dont have an AV receiver or any digital struff...im all analogue.....in old anaologue the transmitter was 80 watts.....the new digital transmitter is100watts......the humm is too loud....i told them way back there was a problem.....mountain has been telling me there is nothing wrong.....they finally lowered the BIT rate....im being told if they lower the BIT rate anymore there maybe no picture......i dunno....stilll having audio and video problems.....im trying to find if it is my stuff, location or maybe the transmitter still has problems.....i hope in was clear and helps so we can solve these problems.....
Floyd>>>>> I don't know if it would help everyone but I would suggest deleting all your AVS cookies and starting fresh.
chuck>>>>how??
Edited by chucklp61 - 8/9/12 at 3:23pm
