Originally Posted by Saoshen
Had my Z (46")for a week or so, my thoughts thus far.
Picture Quality is, IMO excellent. Off angle viewing seems fine to me.
Have not noticed any 'sparkles' yet.
I got the black model. Looks great.
The built in tv guide takes an annoying couple seconds to pop up.
Can NOT do Picture in Picture with different video inputs... Only TV + any other input. You can NOT do video 1 + video 2 PIP. This is extremely annoying, no more watching xbox1 movie in window while playing xbox360.
Picture only DNLA is lame.
The software update says N/A, no updates listed.
Remote is 'ok', but I don't care for the channel/volume controls to be at the bottom. Its a fairly long and thin remote. The blue backlight is nice, although it does not illuminate the labels, only the buttons.
Built in speakers are 'ok' but not great, I run it through to an external amp/speakers anyway.
You can offset individual inputs volume if there is something that is louder or quieter than the others. There is also an auto-volume balance option to help keep the inputs all similar volume, as well a dialog enhancer, bass boost and 'surround' option.
Using only 3 inputs so far:
- xbox v1 (hd av 1080i component, modded, with xbmc)
- xbox 360 (hdmi, hd-dvd drive)
- OTA TV, HD/analog
Main regrets:
- Wish it had been available in 52+ inch size.
- lack of audio/video DLNA is real dumb
- lack of video/video PIP is ridiculous
Other than the above caveats, I am pretty happy thus far.
I replaced a 10+ year old ~32 trinitron crt tv.
This is my first HD/widescreen tv (other than computer monitors).
edit:
I also have used vista media center via 360, which is decent but highly dependent on the source video quality. Alot of it is pretty low quality video (as far as the internet tv portion). I don't have any tv tuners for the computer, so I can't comment on that quality.
Xbox Live seems to have the advantage of higher resolution content so far, compared to MC/InternetTV.
- OTA TV, HD/analog
Main regrets:
edit:
I guess compared to a surround sound system audio isnt that good but you really think the built in speakers are bad? I was really impressed with the sound on this TV for just built in speakers,as long as i boosted the trebble,bass and turned the surround on.
. (actually, like 150+ dollars).
