Originally Posted by seascape
Sound like a quality of product issue then. Most seem to be able to get it serviced to replace a circuit board or two [1-3 trips to the house from a service tech]. This to me means, Panasonic is aware of the issue and has a fix, but it also means they have a quality of circuit boards issue too]. Something causing an unusually high volume of lemon boards.
Anyone know if Panny started getting their parts/boards from somewhere else for their 2008 models? Its all starting to sound that way and quality was sacrificed on the reliability of the electrical components side. This isn't meant to start any bad rumors, I like Panasonic products. It just smells like they got their hands on some substandard components this year.
well, has anyone even responded yet that the replacement boards actualy fixed it? it sounds more like they were guessing when they came up with that solution in the first place.
secondly, if they had so much substandard components i would think other issues would come as well, but so far it seems like outside of this (Which may or may not be due to these faulty boards) there appears to be no other major unfixable issues.
