My third set (which has the flicker) in the PZ80/85 line passed the 100 hour mark yesterday, so today I decided to pump up the settings to post-break-in levels. My plan was to try reaper's fix after I got everything calibrated. But to my pleasant surprise, the flicker has been greatly reduced -- almost eliminated! I viewed material that previously had flicker that now shows none.
To confirm it, I put on Sin City (DVD, upconverted via PS3), which (as those who have the problem know) should've been a prime candidate for triggering severe flickering due to its high contrast, primarily black and white scenes. Throughout the entire movie, there were maybe two or three instances of extremely minor flicker. I have my fingers crossed that the set won't somehow lapse back into flickering later in its life, but for now it appears that I'm in the clear.
Through my experiences and through reading what others have seen, it's my belief that the flicker is somehow related to how the set processes brightness and contrast in any given scene. If you have a set that is "sensitive" (i.e., through a faulty component), your set will have a hard time processing certain colors and shades that appear in high-contrast scenes. Depending on the severity of the problem, setting your contrast and brightness higher seems to alleviate the issue; it worked for me, and earlier in the thread there was mention of it working for others as well.
Hopefully this thread has at least raised awareness about this problem to Panasonic, and I hope my TV remains flicker-free!
