Merry Christmas everybody!
AVS › AVS Forum › HDTV › HDTV Technical › EV's Recommended & Top Rated DTV Indoor UHF/VHF Set Top Antenna Review Round-Up Guide
Featured Stories
Topics Discussed
- itemAntennas Direct C2 ClearStream Television Antenna
- itemChannel Master 3414 4 Outputs Distribution Amplifier
- itemEagle Aspen Dtv2Buhf Directv 2 Bay Uhf Antenna
- itemTerk FDTV1A Flat Digital Omni Directional Amplified Indoor Antenna Black
- itemTerk HDTVa Indoor Amplified High Definition Antenna For Off Air HDTV Reception
- itemTerk HDTVO Amplified HDTV Antenna
Related Forum Threads
- The Official AVS Antenna and Related Hardware Topic! Last post on 6/16/13 at 11:32am in HDTV Technical
- Plano, TX: Which/the best antenna I need? (Antenna web report attached) Last post on 11/11/12 at 5:00am in HDTV Technical
- Madison, AL: Narrowed it to three Antennas for OTA HD... Last post on 2/10/11 at 6:27pm in HDTV Technical
- Channel Master CM 7777 Help Last post on 7/21/12 at 9:39am in HDTV Technical
- Official Samsung LNxxA550 (Series 5) Owners Thread NO PRICE TALK! Last post on 6/17/13 at 4:55am in LCD Flat Panel Displays
Related Reviews
EV's Recommended & Top Rated DTV Indoor UHF/VHF Set Top Antenna Review Round-Up Guide - Page 39
Gear mentioned in this thread:
- EscapeVelocity
- Trader Feedback: 0
- Viziologist, Phd.
- offline
- 4,822 Posts. Joined 11/2006
- Thumbs Up: 17
- Select All Posts By This User
The Radio Shack Budget TV Antenna
Model: T#749
Catalog #: 15-1874
Further refered to as the 1874, is the best of the non amplified rabbit ears and loop antennas, that Ive checked out and tested so far. It has a 7.5 inch diameter loop which shifts the gain curve down into the newly shifted television UHF spectrum ch. 14 to ch. 51 or so...instead of the old ch.14 to ch69 (and even older ch.14 to ch83 spectrum - hat tip seatacboy) spectrum for UHF television signals.
It beats out the RCA ANT108 (ANT110) which was my favorite before. Althought the RS Delta 1868 has fine tuning impedence matching knob which can help it best non fine tuning unamped RE & Loops with tweaking from station to station....I prefer the simplicity of the RCA ANT108 and RS 1874 to it.
Model: T#749
Catalog #: 15-1874
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
Hello Grayson73,
You have some primary stations in each town, and then a secondary market in each location as well that is reachable. It depends on what you are trying to capture. In either place a RS 1874 should be good for the local market at 8 miles to the towers.
If you are trying to get the secondary market stations as well, then it becomes a challenge.
Merry Christmas!
Merry Christmas!
post #1144 of 3240
12/25/08 at 7:36pm
- Grayson73
- offline
- 974 Posts. Joined 2/2004
- Thumbs Up: 10
Hi EV,
So you don't recommend the RS 1892 UFO, Terk HDTVa, Terk HDTVi, Philips MANT940 or Channel Master 4149?
I'm currently using an RCA antenna in Richmond and can pick up all the stations, but have trouble with 65.1, 21.6 miles away. Will the RS 1864 improve things? A little confused as your previous mention talks about the 1874, but you mention 1864 in the paragrah.
8.1 also gives me trouble on the CM-7000, but is fine with the Zenith DTT901.
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
Yeah, I meant 1874, post corrected.
Is your current antenna amplified? Do you have aluminum siding, brick or stucco walls?
I would stay away from amplified antennas, because you have such strong signals....and that may be your problem with 8.1.
The Terk HDTVi or the Philips Silver Sensor PHDTV1 would probably work for you, but you might have to fidget with it when you switch to The CW 65.1 as its in a different direction....and might be in one of the nulls....however you might be able to aim it between somwhere and pull everything in without fussing with it, as you have very strong signals from the main tower cluster which is very close.
The Channel Master 4149's gain curve drops precipitously at the lower end of UHF and you have a couple of high VHF Hi channels to capture as well. So that isnt a good solution.
The DB2 may be your best bet....or the cheaper Eagle Aspen available at Buy.com or Amazon for $15. Its gain curve remains strong into the lower UHF band and gives you some gain on the upper VHF Hi band. It also has a wider beamwidth than the Silver Sensor. You can probably get (at least have a good shot at getting) the 298 degree cluster with the DB2 though you might have to turn the DB2 in order to get it. But it looks like it will work in one position without fussing for everthing down to 65.1....just set and forget.
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
post #1147 of 3240
12/26/08 at 3:15pm
- long beach girl
- offline
- 3 Posts. Joined 12/2008
- Thumbs Up: 10
Hello
I am trying to learn about antennas. I am confused. I had a digital tv and bought a terk-5 antenna. I worked fine. I picked up many digital stations including 7.1-7.3. I now have a flat screen Samsung 750 LCD HDTV. I tried using the same antenna but cannot get several of the stations I had before.
Is it the television receptor? Is it the stations during the transition? ( I doubt it because the old tv was fine just before) Do different televisions need different antennas? I am considering the Terk HDTV but will it make a difference?
According to AntennaWeb I need a medium multi directional antenna. What do you recommend? Please advise I am so confused.
thank you
thank you
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
post #1149 of 3240
12/26/08 at 7:12pm
- Grayson73
- offline
- Thumbs Up: 10
Hi EV,
Thanks for the responses.
The house is entirely brick. The TV is by the window and the antenna on top of the TV or between the blinds and the window (trying both methods). Do the metal blinds touching the rabbit ears make any difference?
I'm using an unamplified antenna that has a rotary knob with 12 positions (not sure what this does) as well as a plate that you can adjust left and right.
In the DTT901 signal bar, 8.1 is showing in the middle to low, so I get pixelation and audio dropouts.
65.1 is showing very low, so no picture nor audio most of the time.
I was thinking that an amplified antenna would boost both of these signals.
DB2 is a no go due to it being an eyesore indoor.
With this new information, is your recommendation still the Terk HDTVi or the Philips Silver Sensor PHDTV1?
post #1150 of 3240
12/26/08 at 7:18pm
- deltaguy
- offline
- 778 Posts. Joined 4/2008
- Thumbs Up: 12
I connected the dipoles to the signal combiner at the start of the month and have found a modest gain in uhf performance. I'm still in the learning curve of just how the dipoles will be of best use. I'll likely mount them off of the tv eventually. Last night was the worst of the year for my Silver Sensor due to wind, also likely to leafless trees affecting the way signal washes ashore here. If this wind occurs after the transition, I'm betting I'll have solid VHF-HI reception with the 3-piece. It's a good set up for people using converter boxes who want reception on the cheap, already own rabbit ears.
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
Brick is a pretty good(meaning bad) radio wave dampening material. And metal blinds act as a reflector(very bad).
The Zenith is a very good tuner.
Get new blinds or raise them and see if that helps.
Alternatively, I would try these antennas.
RS 1874
Philips Silver Sensor or the Terk HDTVi(which has vhf dipoles as well)
DB2
You have very strong signals coming from xmitters just 6 miles away. Amping them may cause overload in the Zenith. So you are stuck with trying to pluck signals out of the air with the best elements you can find.
If you want to try an amplified model, Id try the Petra 32db/Cornet 645A.
The 1892 is a possibility as well, but it can be a bit quirky, not set and forget....but is a dream in the right situation.
I would replace the blinds, work on better placement. (I was just at a friends house, and on analog he was getting absolutely nothing with his rabbit ears and loop.....moved the antenna 3 feet to the side and was getting pretty good signal.
Perhaps go to Radio Shack and pick up the 1892 and the 1874 to start experimenting with. They have a good return policy if neither works out to your satisfaction....but you will be able to learn alot from trying them out.
RS 1874
DB2
post #1152 of 3240
12/27/08 at 1:12pm
- squeeg
- offline
- 4 Posts. Joined 6/2005
- Thumbs Up: 10
post #1153 of 3240
12/29/08 at 9:05am
- seatacboy
- offline
- 897 Posts. Joined 1/2008
- Thumbs Up: 10
Model: T#749
Catalog #: 15-1874
Further refered to as the 1874, is the best of the non amplified rabbit ears and loop antennas, that Ive checked out and tested so far. It has a 7.5 inch diameter loop which shifts the gain curve down into the newly shifted television UHF spectrum ch. 14 to ch. 51 or so...instead of the old ch.14 to ch69 spectrum for UHF television signals.
Model: T#749
Catalog #: 15-1874
EV, I'm impressed. Are you saying the RS 1874 (T-749) beats out the RS1868 Delta as well as the RCA ANT108/110? The larger diameter loop could be a key.
P.S. I've evaluated an RS 1878 powered antenna and it was not quite as good as a Philips MANT510. The results I've had at my suburban (with the antennas I've tried) are very similar to your test results. Have you tried using aluminum foil on the RS 1874 (T-749)?
FYI some really old UHF loops were set up for the old ch. 14 to ch. 83 spectrum. Ch. 70 to 83 were removed from TV broadcasting in the mid-1980s.
post #1154 of 3240
12/30/08 at 9:17am
- Grayson73
- offline
- Thumbs Up: 10
RS 1874
DB2
RS 1874
DB2
Thanks! I tried the 1892, 1874, as well as RCA ANT111 and RCA AND1251.
All of them picked up channel 8-1 well enough.
For 65-1, the ANT111 and ANT1251 had trouble. The amplification didn't help at all. Both the 1874 and 1892 were able to pick it up relatively well, with the 1892 being slightly better. I need to figure out whether I want to pay $50 vs. $12 for the slightly better reception.
I will try the HDTVi/PHDTV1 if I can find it locally.
post #1155 of 3240
12/30/08 at 10:29am
- Rammitinski
- offline
- 17,437 Posts. Joined 9/2005
- Thumbs Up: 21
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
The 1892 might be working very well for pointing at 65.1 (real channel 47) and then just leaving it in that direction. It will probably pick up the rest off the side well enough for rock solid reception, so you can set it in one position and forget it(and if you are feeling frisky you can try for the channels in Red at 298 degrees now and then.
Another option is to go for the Petra SuperPower 32db at Buy.com for very cheap. $7 plus shipping ($15 total). Its got a larger diameter loop and a thicker diameter loop as well....both being improvements for reception of UHF TV over the 1874. It also has VHF dipoles for the upper VHF channels you have and an integrated amplifier. Very nice unit....a Best Buy.
Ive been contemplating working on the front page, doing some Best Buy and Products of Special Merit type labels.
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
post #1158 of 3240
12/31/08 at 12:54pm
- fred2ka4
- offline
- Thumbs Up: 10
Just purchased two antennas off of ebay.
1) Radio Shack DA-5200 (new)
2) Radio Shack 15-1880 (new)
The 15-1880 was new in the box for $20 shipped so I could not pass it up and the DA-5200 was also new for $40 shipped. I just want to see which one works better for my application but I would not have even come to these conclusions if it were not for the testing done here.
I'm still waiting to see if any good reviews come of the Toptronics DA-001
Thanks Again.
Thanks Again.
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
post #1160 of 3240
12/31/08 at 2:46pm
- fred2ka4
- offline
- Thumbs Up: 10
Thanks. I was actually watching an RS 15-1862 and another 15-1880 which are still available when I came across the 15-1880 for $20 buy it now shipped and new in the box (left over inventory).
I am also looking at a Clearstream2 but I will wait on that until I see the results of these antennas first and I am still trying to find some test results on the Toptronics DA-001, but nothing yet.
post #1161 of 3240
12/31/08 at 10:18pm
- racinmd
- offline
- 26 Posts. Joined 12/2006
- Thumbs Up: 10
For all of you using pole lamps for your antenna mounts consider one of these. Good excuse to throw a festivus party year round.
http://www.festivuspoles.com/pages/Festivuspoles.htm
mdr
mdr
post #1162 of 3240
1/1/09 at 4:16pm
- bmarchand
- offline
- 20 Posts. Joined 3/2008
- Thumbs Up: 10
I just bought a Clearstream C4 for $61 plus shipping and it is the best antanna I have tried. I had previously used a Silver Sensor, Terk HDTVa, Channel Master 4221, Channel Master 4228 and AntennaCraft Y10-7-13. The silver sensor and Terk HDTVa worked but they are so directional they were too touchy and so could be a pain having to constantly adjust them plus they do not have as much gain as the outdoor antennas for dxing. Since I live in a first floor apartment duplex I can not put antennas outside so I put them behind the tv. I have combined the Antennacraft Y10-7-13 with the C4 using a Diplexer to get real channel 9 65 miles away that would never come in on the UHF antennas.
I live in Chatham, IL 5 miles south of Springfield, IL. The Clearstream C4, CM 4221 and CM 4228 all pick up most stations at 100 percent but the C4 wins on the weakest station. The channels listed are the real digital channels.
WILL 9 PBS about 65 miles away. I could only pick it up with the Antennacraft Y10-7-13 in a spare bedroom and then it still only comes in half the time. No UHF antenna will pick it up. I wanted WILL 9 because it is the only PBS station on 24 hours a day I can receive.
WSEC 15 PBS about 20 miles away. I can pick it up 100 percent on the C4, CM4221 and CM4228 if pointed at its tower but its tower is in the opposite direction as the other stations so it comes in around 72 percent from the backside which still provides a steady picture.
WAND 18 NBC is about 55 miles away and the C4, CM4221 and CM4228 all pick it up usually at 100 percent or close to 100 percent.
WBUI 22 CW is about 55 miles away and the C4, CM4221 and CM4228 all pick it up usually at 100 percent.
WICS 42 ABC is about 20 miles away and the C4, CM4221 and CM4228 all pick WICS up at 100 percent.
WRSP 44 FOX is about 20 miles away and the C4, CM4221 and CM4228 all pick WRSP up at 100 percent.
WCFN 53 MyNet/CBS is about 20 miles away. WCFN is low power at only 1.8kw. They are supposed to upgrade soon moving to real digital channel 13 but its another Nexstar station who has not had the money to build full power digital stations. This is where the C4 wins. I get a 79 percent signal on the C4 but the CM4221 and the CM4228 can only get WCFN at 50 percent no higher. The C4 also holds a steady 72 percent. The CM4221 and CM4228 will fluctuate in the mid to high 40's.
The C4 also wins in that it can pick up stations from a wider angle than the CM4221 and the CM4228. The CM4228 is especially narrow in the direction it can be pointed as is well known with a narrow 15 percent angle. And being so big can be hard to turn much because it takes up so much space. So the C4 also has the advantage of being smaller and lighter in weight.
Comparing the CM4221 and the CM4228 they seem to work about the same for my conditions but in the summer when I can pick up Saint Louis stations at night in the humid weather the CM4228 picked up the Saint Louis stations a little stronger than the CM4221.
If anyone is wondering if they should buy a clearstream antenna my results are the C4 works better for me than the CM4221 or CM4228 by a little on a weak station. Also WCIA digital real channel 48 which is 80 miles away was coming in pixeling on the C4 but not at all on the CM4221 or CM4228. I do not need WCIA as WCFN is a simulcast but it is an example.
If anyone wants to buy my CM4221 or CM4228 I will sell it to you at a fair price. Both were bought in the summer of 2008 and used inside their cardboard box behind my TV. I do not need them anymore. The CM4228 takes up so much space it would especially be good if someone wants it.
I also tried the Winegard HD-1080. I did not like it. I could not get WILL which was the reason I bought it but it was not rated to pick up stations that far away anyway at 65 miles away. I did not like how the bowties on the Winegard HD-1080 move. The CM4221 and CM4228 are made better and more sturdy being steel rather than aluminum. It seemed the Winegard HD-1080 worked about as well as the CM4221 for UHF but I could not keep it in its box to sit up like the CM4221 and CM4228.
post #1163 of 3240
1/1/09 at 4:55pm
- TheOpenBox
- offline
- 37 Posts. Joined 1/2008
- Thumbs Up: 10
Has anyone tried out the Monoprice OTA Antenna ?
It's not too bad of a price.. I'm not quite sure of I should pull the trigger on this one..
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
Thanks for that overview bmarchand! Very informative.
I dont like the 4228.
I do very much like the Channel Master 4221 and 4220 in the old style, not the new Chinese style.
I gave the edge to the Antennas Direct ClearStream2 over the 4220. So your appraisal seems to be inline with that....seeing as you like the ClearStream4 over the 4221. Thanks for the in depth analysis of backside reception and beamwidth...between them.
The 4220 and 4221 are much cheaper than the C2 and C4, so they have a considerable value advantage for most. However I dont like the newer Chinese produced models and the C2 will take its place nicely.
Dont forget the C1!
Good antennas. I posted some good info on them from another forum where the owner of Terrestrial Digital was communicating about them. That seems like a good addition to the front page as well for further write ups.
Thanks again for sharing!
Dont forget the C1!
post #1166 of 3240
1/1/09 at 5:42pm
- Rick313
- offline
- 521 Posts. Joined 5/2008
- Thumbs Up: 10
Thanks for your comprehensive and informative comparison and contrast of the various antennas you've tried. I'm a little surprised since I haven't seen any rave reviews of the C4 until now. Nice to know that someone is having good luck with it!
By the way, it's nice to hear from someone in central IL. I lived in Springfield for 15 years before I moved to Denver about 3 years ago.
Happy new year!!
post #1167 of 3240
1/2/09 at 2:04am
- bmarchand
- offline
- Thumbs Up: 10
post #1168 of 3240
1/2/09 at 2:30pm
- wreck58
- offline
- 37 Posts. Joined 8/2008
- Thumbs Up: 10
It works well for me. I'm 30 miles north of the antenna farm in Dallas. Placement in a window worked the best for me, although my window faces east.
- EscapeVelocity
- Viziologist, Phd.
- offline
- Thumbs Up: 17
post #1170 of 3240
1/3/09 at 7:19pm
- holl_ands
- MS-Comm Engineer
- offline
- 3,263 Posts. Joined 6/2004
- Thumbs Up: 20
Preparing for 17Feb, I analyzed High-Performance (i.e. not small) DIY
Zig-Zag Hi-VHF Band Antennas (such as would be installed in an ATTIC).
See post in DIY VHF Thread:
http://www.avsforum.com/avs-vb/showt...php?p=15451710
Back to Forum: HDTV Technical
- EV's Recommended & Top Rated DTV Indoor UHF/VHF Set Top Antenna Review Round-Up Guide
Currently, there are 1178 Active Users
(177 Members and 1001 Guests)
Recent Discussions
- › 'Mad Men' on AMC HD 21 seconds ago
- › The East Coast TV's Experiment 2 minutes ago
- › Are PMs private or are they read by AVS admins? 3 minutes ago
- › Lexington, KY - HDTV 3 minutes ago
- › My HT\2ch setup 4 minutes ago
- › Official Samsung UNXXF7100 Owners Thread 4 minutes ago
- › The New Master List of BASS in Movies with Frequency Charts 5 minutes ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 5 minutes ago
- › **Official EMP Owner's Thread** 5 minutes ago
- › Best sub for space limits of 16h x 20w x 18d 6 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BDP-S5100 3D Blu-ray Disc Player with Wi-Fi by imagic
- › Yamaha Aventage Blu-ray Player Black - BD-A1020 by foursticks
- › Panasonic DMP-MST60 Smart Network Media Streaming Player with... by amesdp
- › Sonax E-0062-BF Fiji 60-Inch TV Component Bench, Ravenwood Black by DDT0C
- › OPPO BDP-93 Blu-ray Player by KingLeerUK
- › Sony Blu-ray Disc Player - BDP-S790 by wisccheese
- › Samsung BD-C6500 1080p Blu-ray Disc Player by NeonSignedOff
- › Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player by bettzysdaddy
- › Panasonic DMP-BD65 Blu-Ray Disc Player (Black) by dasher123
- › Where's The Wires, LLC Streaming Media/Soundbar Power tool by wheresthewires
View: More Reviews
New Articles
- › Why is LED light known as long life by Davidsmith001
- › Blu Ray Player Review Contest by Mike Lang
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
