Originally Posted by EscapeVelocity
Did you try the old RE&Loop at the "Sweet Spot" you found. You said that the PHTV3 was only a tad bit better than the PHTV3 at its original location, until you lifted it with phonebooks. This will give an indication on whether its the antenna or the "sweet spot" that is producing better results.
Indeed, YMMV seems to be the story with indoor antennas.
I did try our old RCA ANT120b in the "sweet spot." It locks in the local CBS, FOX, ABC, and NBC slightly better than it did pre-phone books, but PBS is still all over the place. The PHDTV3 shows higher signal strength across the board on all channels (about 5-15% of the signal meter on our Zenith DTT900), but more important for me is that PBS and it's 3 subchannels comes in solid.
Also, the PHDTV3 pulls in the Ion affiliate at about 60% strength--very watchable, especially at night--whereas the rabbit ear/loop combo wasn't doing the job at 30%.
So, yeah, the sweet spot helps, but ultimately the PHDTV3 turned out to be the right antenna for us. We would've bought a different silver sensor style antenna, but they don't sell them in any store locally.
