Originally Posted by holl_ands
Since you are talking about a digital TV channel (8.1), you apparently obtained either
a CECB or a HD OTA Tuner for either your old analog tube TV or your "newer" HDTV
(you didn't say what you are now using).
If you can see the digital video picture and can't hear audio, the problem isn't in the antenna,
it is either a volume control problem in the external OTA Tuner (read the owner's manual
or let us know what you're using) or (if you are using Red/White/Yellow connections) there
is a cabling problem.
It would help if you let us know exactly which external tuner you are using and whether
you connected it via the Ch3/4 RF Output or the Red/White/Yellow Audio/Video output.
I am using the Radio Shack Budget HDTV Antenna straight to the Antenna IN on my Toshiba 56hmx96 HDTV. It's not a "newer HDTV", so I'm not sure if that's the problem that I'm using a TV purchased before the digital switch? Also, all of my other channels I get are just fine with audio AND picture, it's just this particular ABC channel (8.1).
I am not using a tuner at all. Also, I live somewhat down a hill and I have used the same antenna at my friend's house on his "newer" HDTV that was purchased AFTER the Digital Switch and he gets audio just fine on channel 8.1 and all other OTA Channels.
Again, before I purchase the Amplified HDTV Antenna from Radio Shack, I want to know if that will make a difference or if the being located at the bottom of a hill is the biggest problem. If that is the problem, will the amplified antenna help me with that channel or get me another ABC channel since it's "amplified"?
