I tried the DIY antenna and it was slightly worse than the large directional antenna. Removing the distribution amp also reduces the reception quality. Adding attenuators reduces the signal strength & picture quality so IMO it's not a "signal is too strong" problem. I have not eliminated the in-wall wiring and connectors; my next step is to try the antenna outdoors on my front lawn (as an experiment). If that works then I'll try to work out an effective roof mount option.Originally Posted by Dave Loudin
But, but, but... Check out the signal strengths available before obstructions! One check and one suggestion:
Is the Terk pointed east? (have to ask) if so, then...
Bypass the distribution amp and connect just one outlet to the cable from the antenna. Before you mentioned the local obstructions, I was thinking you might be overloading the amp even after 100 feet of cable. You have nine signals with noise margins of 60+!
For a DIY, try the bowtie array documented at http://m4antenna.eastmasonvilleweather.com/index.html. It's pretty easy to build and is easy to work with in the attic. Be prepared to try adjusting the antenna's aim if pointing east doesn't work.
