AVS › AVS Forum › Audio › Speakers › Do you want a neutral and correct speaker?
Do you want a neutral and correct speaker? - Page 17
post #481 of 511
I like green eggs and ham...
post #482 of 511
Originally Posted by NIN74 View Post
No. Think about it. If you listen to a "bad" recording that have too much treble. A more neutral and good speaker will reproduce that without adding more treble and distortion. The recording will sound "bad"
Take speaker 2 that are adding more treble and also add distortion to the sound. Then the recording will sound even worse.
So I would say that a neutral speaker will sound best on all music.
How do "less than adequate" electronics fit into this, in your opinion?
I have a Denon CD changer that, upon first listen, sounds very dynamic and detailed. But with more listening you realize that it is bright, annoying and harsh. You know what I do with it? It's feeding a Carver front end that is driving Advent Heritage speakers.
Presto! The bright Denon coupled with the fat, laid back sound of the Carver amp and the warm, rolled off Advents works and sounds great.
My point: all speakers have a place and use. You just need to experiment a bit.
post #483 of 511
It all depends on the drugs!!!
Excellent point! Some drugs make everything sound fantastic!
post #484 of 511
Originally Posted by lwien View Post
So in answer to your original question NIN, is YES. I would like a neutral and correct speaker, but the problem is, is that it doesn't exist and if it did exist, what would be neutral and correct for me, may, and very likely will NOT, be neutral and correct for you.
And if you disagree with what I am saying, than please respond to my previous post.
This is not true. Why? Because you HAVE a reference! For exampel, if a speaker dip 10 dB at 300 Hz i cannot be correct and neutral.
This "everything is different preference, nothing is wrong" is crap that bad magazine like TAS and other say, in anther word, advertising.
Yes, there are some different preferences, but if Elvis sounds like Paul pott, you cannot still say "it is neutral and correct for me".
But to many audiophile have lost the most fundamental about high fidelity and now believe that "because no speakers are 100% perfect, then all can be right". Which is wrong, just like a projector adding blue tint on all movies, are not a correct projector.
post #485 of 511
Originally Posted by jnickrand View Post
I think we're all supposed to bow down to the Ino Audio (or whatever they are) speakers that NIN has because nothing else is even close to being as neutral or accurate as his speakers. That's what he wants. He wants to know why we have crap and he has the best so why not feed his ego.
Did I say that? No. I have heard other speakers that are VERY good, like Revel and Respons, for exampel.
post #486 of 511
Originally Posted by david-me View Post
OMFG What a Prick! Grow up... If you would like, I could paypal you a quarter so you can buy a life...?
I answer him in the same manner as he answer me.
post #487 of 511
That is an illogical leap that I would never make. Who here said that?
post #488 of 511
Of course one must have good equipment before the speakers (and the room, of course), but I don't agree with you to try to fix a problem with anther problem, a "anti-problem". The reason is that it is almost impossible to have a perfect anti-problem that fix the problem without adding another problem.
I believe that it is much better to focus on EACH part in the system, trying to get equipment that do color as little as possible.
post #489 of 511
post #490 of 511
Is there one audiophile on this site that would say that a 10 dB dip at 300 hz is neutral and correct? IMO, no there is not.
Are you arguing that the best speakers must be ruler flat, since all else inaccurately add to the source music?
post #491 of 511
I don't think you are understanding what others are trying to tell you in this little thread you started. People like different things in a speaker and no speaker is perfect.
Another poster made some comments about bad recordings, IMHO in that case a less revealing speaker would obviously not reveal as many of the recordings flaws, so could sound better(less annoying) in that instance.
Likewise superb recordings generally sound great on most systems. Ever wonder why a lot of hi fi shops play jazz? Its easier to reproduce, is usually recorded fairly well and will make most systems shine. (No offense to jazz lovers.)
Ever wonder why you should always bring your own CDs to demo speakers or any other equipment for that matter? For the exact opposite reason than the question above.
P.S. who says a warm sounding speaker is a problem? They are a part of one hell of a good sounding system for when I am slamming back some beers in my garage.
post #492 of 511
" Ever wonder why a lot of hi fi shops play jazz? Its easier to reproduce, is usually recorded fairly well and will make most systems shine."
I never heard that one before. Maybe you wanted to say smooth Jazz?
post #493 of 511
And, apparently, every speaker.
post #494 of 511
In an ideal world that would be true.
Although I've read some possibly extreme examples, the basic concept is correct: reproduction of sound in a home environment is all part of a system (as you correctly point out---the room is a really big factor in that).
If you could find a speaker that measured essentially flat across the entire audio spectrum----the resulting sound may not actually be all that pleasant. When you read comments from people who have tried using parametic equalizer and test tones to achieve that---at times the resulting sound is described as "too bright". I know that's what I found when I did it.
I think the reality is that you actually do have to find components, along with proper room treatment, that compliment each other---and the devil is in the details.
post #495 of 511
Sure? Some really high priced speakers have a really bad FR.
No, everything is not extremly flat FR.
post #496 of 511
What is the problem?
For exampel, if you have a pre-amp that is bright sounding, you cannot find a power amp that make all the problems with the pre-amp go away without adding another problem.
post #497 of 511
How do you know that? I would say that based on my own experience it is not true in almost every case. Because you are adding more problems to the problems in the recording, and they will interact and blend to a bigger problem in most cases. I have tried it, using a tube amp to "soften" problems with modern metal and pop/rock recordings, and I would say that in almost every case, it got worse. Not only can it sound worse, I also get the same "sameness" on all music. Not fun at all IMO.
post #498 of 511
This sound really strange. First, do you know if its the parts before or after the speakers that are the problem? If one don't have very transparent chain before the speakers, one will hear those problem and that is not the speakers fault.
Secondly, I hope you don't think that flat FR is the only thing and that fixing a speakers bad FR with parametic eq, is the same as a speaker with a good FR?
The best way, in my opinion, to have the best high fidelity system, is to look at each part in the system and go from the start to finish.
post #499 of 511
NIN, are you the audio science professor at the university of Scoghall? Your posts are really academic.
post #500 of 511
I don't know that. Thats why I used words and accronyms like "could" and "IMHO".
FWIW, your thoughts on bad recordings and less revealing speakers creating more problems is entirely possible. But keep in mind its just a theory, as was mine.
post #501 of 511
Even if one have the most measured flat FR speakers, the research shows that a perfectly flat respons at the listening position is not desired among most listeners, that's what I think petergaryr is talking about.
/Chuck
post #502 of 511
One of the things that sometimes gets lost in these type of discussions is what standard is being used to judge "accuracy". There are certainly measurements that can be done...and they do have their place.
When I evaluate anything, the standard I use is live music. I've been a vocalist in a band for close to 20 years. At least for my purposes, I know what our band sounds like. If I listen to a recording of it, I can tell fairly quickly how accurate the "chain" is from recording through electronics to speakers.
I've also attended a number of classical concerts so I'm pretty familiar with what an orchestra sounds like (factoring in the hall acoustics).
So, all I'm saying is that if the end result produces "accurate" representation of live music, then I am satisfied. Sometimes that means mixing and matching components to compensate for minor irregularities.
post #503 of 511
/Chuck
Correct.
post #504 of 511
This has been the basis of getting better than average sound all along. Great point.
post #505 of 511
Even if one have the most measured flat FR speakers, the research shows that a perfectly flat respons at the listening position is not desired among most listeners, that's what I think petergaryr is talking about./Chuck
Otherwise everyone prefers studio monitors as opposed to B&W's...
post #506 of 511
I prefer B&W's
post #507 of 511
I like toast
post #508 of 511
rye
post #509 of 511
Johnny Walker, Blue Label.
post #510 of 511
Green Label is better and cheaper too!
  Back to Forum: Speakers
