AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Disabling HDMI audio on my HD-A20?
post #1 of 7
I've looked through all the menu options and I'm not finding a way to accomplish this. Sure there must be a way?
post #2 of 7
may I ask what the harm is in keeping it active?
post #3 of 7
Harm? This isn't the most uncommon type of request when it comes to a movie player, you know?
I'm getting sick of lowering the volume on my TV every time I feel like watching an HD DVD. All of my other devices allow HDMI audio to be disabled. I only listen to the audio coming from the TV when watching cable.
post #4 of 7
As far as I know you cant turn it off. you will have to turn down or mute your TV when using HD DVD.
post #5 of 7
Boo.
I'd settle for muting the TV if it weren't for the fact that it insists on displaying a mute icon onscreen.
post #6 of 7
If your "TV" has a disable audio option for it's speakers, get a Harmony remote and program it to disable the TV speakers when switching to HD DVD. You can then switch back and forth with the touch of one button. I like how when I press "Watch an HD DVD," it switches inputs, powers on my XA2, and my correct speaker settings after hitting the one button. The programming capabilites of a Harmony remote is endless. I'm sure you could even have it lower the volume on the TV when switching if your TV speakers cannot be disabled.
post #7 of 7
Nifty! I'll look into one. Thanks.
  Back to Forum: HD DVD Players
