Originally Posted by
giomania
In order to implement my desire to have the Radiance XS-3D distribute signals to both my HT and my family room systems, but not always at the same time, it requires I place an HDMI 3 x 1 or 4 x 1 switch after the Radiance. I want to ensure the switch I get will pass 3D and 1080p/24. This switch at Monoprice, appears to fit the bill:
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=8462&seq=1&format=2
Here are the listed specifications:
3X1 Enhanced HDMI® Switch w/ Built-In Equalizer & Remote
Specifications
Maximum Video Resolution 1920x1080 (1080p)
Video Input 3x HDMI®
Video Output 1x HDMI® with HDCP and 3D support
Vertical Frequency Range 50/60Hz
Video Amplifier Bandwidth 250 MHz / 2.5 Gbps per channel
Supported Video Resolutions 480i, 480p, 576i, 576p, 720p, 1080i, 1080p
Color Depth 12-bits per channel (36-bit total)
Supported 3D Formats 1080p @23.98/24 Hz, 720p @59.94/60/50 Hz, bandwidth up to 250 MHz
Supported Audio Formats LPCM, DTS® Digital, Dolby® Digital, DTS-HD Master Audio™, Dolby TrueHD™
Input Power Requirement 5V DC, 2A
Power Consumption 5 Watts
Operating Temperature 0°C to +70°C
Operating Humidity 10% to 85% RH (no condensation)
Storage Temperature -10°C to +80°C
Storage Humidity 5% to 90% RH (no condensation)
Dimensions 6 1/16" wide by 2 23/32" deep by 29/32" tall (1" including feet)
Weight 260 gm
I would appreciate any input.
Mark
