AVS › AVS Forum › Video Components › Video Processors › Official RadianceXD support thread
Official RadianceXD support thread - Page 13
post #361 of 1246
Originally Posted by Dave G View Post
Oh man thanks for the invite but I don't play cards Not that I don't want to, I just don't know how... never learned.
(Also flying out tomorrow morning for work... so not the best timing.)
Deinterlacing:
Menu -> Input x -> Video Setup -> (choose resolution) -> Control -> Deint -> Mode. If the resolution is not progressive, you should be able to choose between, film, video, or auto. Auto is pretty much useless as far as I'm concerned.
Well...we actually like people that don't know how to play cards.
Thanks for the info.
I'll try to program it in.
Remember, I'm not very bright about this, so how does it help the video image?
Mike
post #362 of 1246
Hey Hog, we have PiP now too
And more importantly, a 'video' deinterlacing mode, which is the cat's pajamas if like me you watch a lot of recorded cable.
Man, it's like another Christmas for me! It's days like these that I'm glad I switched to Lumagen from DVDO. Owners of DVDO's newer gear are still waiting for features that it's already spec'd to do - and here we are getting extra goodies on a regular basis, for free!
post #363 of 1246
Mike
A *lot* less combing for video sources - in fact it disappears altogether. But then again, that's one artifact I'm really, really sensitive to, so YMMV. If you don't think there's anything wrong with the image I'd say don't touch anything. To me it was really easy to see though, particularly on the mouths and hands of news show hosts.
post #364 of 1246
Deinterlacing:
Dave -
Thanks for the "how to" and explanation.
I made the change, but haven't had the chance to A/B to look at any differences.
BTW - I was out first in our Texas Holdem' game.
Mike
post #365 of 1246
Some HD material like the Fifth Element who are 1080 x 1920 24Hz p, do have black areas at the top and the bottom. With cropping them away (Input > .) I was able to reduce the active size to 817 x 1920 and increase the frequency to 72 Hz respecting the max acceptable clock. See my posting here. http://www.avsforum.com/avs-vb/showt...6#post18046786
Some other HD material like the Fall are also 1080 x 1920 24HZ p, but need the full high of 1080p as active size. So I should not crop top and bottom. And as a result of this only 1080 x 1920 p at 48 Hz p is acceptable with not overshooting the clock.
What is the correct concept of assigning this two different crop settings ? And how do I link the corresponding output configuration for them? Physical Input is always the same player (Oppo, source direct)
post #366 of 1246
@Doug:
1 question:
It's better calibrate KRP + Radiance in a "ISF" bank or in a "AV pure" bank ?
I think in a "ISF" ,becouse have best overall performance than the av selection,right?
post #367 of 1246
If you want access to user menu settings on the KRP, use Pure mode. If you don't care if the user menu controls are disabled, you can use an ISF mode.
Pioneer has said repeatedly that Pure mode disables the most (probably unwanted) processing and that the ISF modes do the same thing re. the processing steps that are disabled.
post #368 of 1246
big blue too asked: What is the correct concept of assigning this two different crop settings ? And how do I link the corresponding output configuration for them? Physical Input is always the same player (Oppo, source direct)
You can use different memories for this purpose. There are 4 memories, A-D, for each input resolution type. If that's not enough and you have unused HDMI inputs you can use the unused inputs memories as "virtual" memories for the input of interest. If you needed a different output config for this different cropping it's also in the input menu under Input:Video Setup:RES:Out1 or Out2 Select. This selects the output config for a given input resolution and memory.
post #369 of 1246
Thakns Doug ,i prefer ISF beacouse have deeper black and more lumens than other AV selection.
post #370 of 1246
Steven, why do you think the ISF mode is "blacker" - I see no evidence of that - panels have a "native" black level that does not change in different modes. The only time the Kuro panels get darker than their native black level is when you leave an all black screen on the display for some period of time, in that case, after a time-out (30 seconds or 15 seconds or something like that) Pioneer turns the panel off completely and the black is just as black as when the panel is turned off - but you never see that "total blackness" in any image. As for "more lumens" - you probably mean more foot-lamberts - it's just not necessary for viewing movies or TV in a dark room. In fact, making the picture brighter than Pure mode allows in a dark room will cause squinting and/or eye-strain because the screen will be too bright for comfortable viewing in a dark room. If you want more screen brightness for viewing with daylight in the room, ISF mode is completely unnecessary as the light coming into the room "de-calibrates" the TV anyway. There's no real benefit from using ISF-Day or Optimum or even Standard mode with daylight in the room because the daylight changes color constantly during the day and because the daylight make calibration impossible.
The ISF modes may "sound good" on paper, in real-world viewing, they don't really do anything very helpful, except give you modes that block out all the user menu settings so that other family members can mess with your calibrated settings.
post #371 of 1246
So doug there is no difference to calibrate kuro with radiance between AV pure and ISF?
post #372 of 1246
Thank you Patrick, works fine with unsing Mem A and Mem B for different cropping
post #373 of 1246
Maybe a psychological improvement, but nothing measurable... unless you want a brighter Pure mode for a room with light coming in windows... but as I mentioned, when light comes in the windows, the light "de-calibrates" any video display and because the light changes all day and as clouds come and go, the way the TV is "de-calibrated" changes constantly also. So you can't really compensate for that. So it really doesn't matter much what mode you are in if there's light in the room - all of them will be de-calibrated in many ways by the light.
post #374 of 1246
New firmware update - couple of bugfixes
XD - Production 012510
XE - Production 012510
XS - Production 012510
Production 012510- Bugfix for game mode with interlaced inputs only showing top half of screen (bug occurred at 011410 revision). Bugfix for the Pip Setup menu command where in a particular situation the values would jump as you entered the command.
post #375 of 1246
Are there any plans on the drawing board to add DSD passthru to the XE? I guess the real question is whether the conversion process from DSD>PCM is difficult, whether sending DSD would avoid any possible jitter, and whether my Pio SC-07 would do a better job than my Oppo 83. I have to admit, it does look pretty cool when the DSD>PCM text lights up and it says "SACD" on the SC-07's display
Now that I have an XE in my system, I'm thinking it would be nice to have this feature. I know it was pretty low on the list a while ago, but I'm hoping it's maybe moved up a bit?
post #376 of 1246
Firmware Update 021310 - direct download links:
XD
XE
XS
Production 021310-
Bugfix for bug in 021210 revision that with Pip and certain source combinations could cause a video source to be lost until switching to another input and back. Bugfix for output mask command when used on inactive output configurations.
The mask command bug is something I reported. Last night.
(Yes, I stole Mike's formatting. Sorry Mike.)
post #377 of 1246
I upgraded to the latest FW:
Production 021410- Bugfix with new Pop command when zooming on main window.
Production 021310- Bugfix for bug in 021210 revision that with Pip and certain source combinations could cause a video source to be lost until switching to another input and back. Bugfix for output mask command when used on inactive output configurations.
Production 021210- Adds Pop (picture-outside of-picture) to the already implemented Pip command. The 'Pip Setup' command is now called 'Pip/Pop Setup' and is located under the 'Other' menu. The new 'Pip/Pop Setup' command now has a 'Type' option where you can select 'Pip', 'PopL' or 'PopR'. 'PopL' stands for 'Pop Left' so the secondary video window will be to the left of the main video screen. 'PopR' is for the secondary video window to be placed on the right. For Pop you can vertically orient the side-by-side screens to be at the top, centered or bottom of the picture and adjust the y position from there. Also some small improvements to Pip in this update.
I used two HDMI sources and did POPL, Center, Image size = 50.
The pic is enclosed.
(sorry, poor iPhone pic)
It looks like you can't have both side by side images at 100% height?
Is that a limitation of bandwidth or will it be fixed in a later FW iteration?
Mike
post #378 of 1246
No, not a bandwidth issue. Just the first iteration of Pop functionality.
post #379 of 1246
Patrick -
Thank you for the fast response.
So, further FW updates should allow full height side-by-side POP images?
Great!
That will be cool.
Mike
post #380 of 1246
We're planning on it...
post #381 of 1246
After the latest FW, the following happened:
- played Wall-E from Oppo 83 -> Lumagen RadianceXE -> HDMI output to AVR (Denon 5308CI) and HDMI output to JVC RS20.
- the Wall-E menu and initial part of the movie had sound and then it stopped!
I tried forcing an HDMI handshake by switching on/off or changing inputs on the devices.
When I went back to BR menu there was sound (so, suggesting no problem with cable) but the movie was silent.
Weird.
Anyone else have anything like this happen?
I'll re-test today.
Mike
post #382 of 1246
Weird.
I'll re-test today.
Mike
I tried the same thing with another BR this morning and same problem -- menu has audio and video, but the main part of BR has video only.
Other Radiance inputs for Oppo DVD and HDTV from cable work normally.
Any suggestions, or do a FW force backdate?
Mike
PS - I didn't change any Oppo BDP-83 settings, so only change was RadianceXE FW update...
post #383 of 1246
Go back to 012510 or earlier if you want to bitstream. In the meantime, PCM works fine. I have fired off an e-mail to support, and I am sure they will have it fixed soon.
post #384 of 1246
I had tried flipping HDMI Audio formats in the Oppo to troubleshoot from:
Auto->LPCM->Bitsteam
...but must not have left it at LPCM long enough.
LPCM works.
Thanks for the input.
Glad to have that working again.
Hopefully this small bug will get fixed.
It was a surprise/annoyance though.
Mike
post #385 of 1246
This was posted over in the XE/XS vs DUO thread:
Originally Posted by Fudoh View Post
Bottom line was: yes, the Lumagen units have a bunchload of settings which DVDO's machines don't offer, the CMS is outstanding of course, BUT for me Lumagen's combination of the VXP processor with their FPGA was a wrong approach. The VXP's deinterlacing qualities can't reach what ABT did with the 50pro and every step by Lumagen to fix the holes (manual filmmode etc) overrides the VXP completely, so you eventually loose the NR features of the Gennum processor. I won't say that you can't be 100% happy with a Radiance, but for me the 50pro along with a VideoEQ seems the better approach. This is especially true if you have used the manual DI settings of the 50pro a lot (which I do).
Besides pure DI-quality the EE/DE features do *a lot* for SD material (and even HD). Gennum's sharpening tools are a joke in comparison and are (again) completely lost when choosing a fixed filmmode with overrides the VXP. A near perfect video processing chain for SD DVDs was a ABT2010-based Oppo Player as a source, a Radiance for scaling and color issues and a DVDO processor for EE/DE after scaling...
I've underlined the areas of interest. Is this true, that the manual film deinterlacing mode is a "fix" and that when activated it prevents the use of the Radiance's EE/DE/NR features?
The second underline portion of text is a bit subjective, but I was curious if anyone else has made the comparison as well, as I was under the impression from some rather knowledgeable people that the EE/DE/NR algorithms in the VP50Pro/ABT 2010 weren't very good compared to other solutions.
post #386 of 1246
don't know why you're carrying the discussion over here into this thread.... my major complain in the Radiance's sharpening tool is that it's applied in the final stage of the VXP processing BEFORE the scaling, while ABT's EE/DE is applied to the scaled image allowing much more subtle adjustments (especially for SD sources).
You can read about the fixed filmmode in this thread and in Lumagen's update section on their website. When enabled the deinterlacing is done in the FPGA section instead of the VXP. NR features are disabled.
And, yes, of course, we don't have to argue about ABT's MNR function. Is way behind what the VXP can do.
post #387 of 1246
Because I was curious and wanted more information given your comments, and last I checked this is the repository for information and knowledge about the Radiance - which I own. Don't know why you care why I asked for a verification about your comments unless you took my question personally.
post #388 of 1246
na, don't worry. Just like to follow my own postings and distributing them over various threads doesn't make it easier
post #389 of 1246
New Radiance XD user here. I got to spend some time doing a basic set up last night. I have 4 sources, DirecTV HR-22, Oppo BDP83, Toshiba HD-A3, and AppleTV. I have a few questions if you don't mind:
1) For DirecTV, does anyone have any recommendations on noise reduction options, for specifically different ones for 480i, 720p, and 1080i? Video or Auto de-interlace?
2) Does anyone try to use 24p for some prime time broadcasts? Or is it too much of a hassle? If you do, do you just use a different input memory and use forced film mode?
3) For Oppo, I just do source direct on the player, all resolutions but 1080p/24 go to 1080p60 ouput, 1080p/24 goes to 1080p24. inputs other than 1080p24 get video de-interlace. Sound good?
4) I intend to use YCbCr-4:2:2 for all inputs if possible. Any preference for something else? DirectTV seems to support 4:4:4 only.
5) I intend to use YCbCr-4:2:2 for all outputs. I assume to get 10 bits per channel output, I must use a 4:2:2 method? (in other words, 4:4:4 RGB or YCbCr are not 10 bits per channel)
6) I did a quick pass at color gamut correction. I got all Delta-E's under 3. I set white at -40,-40,-40 to help get some luminance back for some colors. What delta-E do most feel they need to be successful?
7) HD-AV3: I just force all inputs (limited to 1080i on this player) to 1080p24 output and use forced film deinterlace mode. I have very few HD-DVDs, and I think they are all film based.
Sorry for all the questions. My past experience was with a HDP, and so far I am really liking the Radiance.
P.S. forgot to mention the display is a Pioneer FPJ1 projector (RS2 clone)
post #390 of 1246
Firmware Update 021810 - direct download links:
XD
XE
XS
Production 021810-
Bugfix for intermittent audio issue which often affected HD audio formats (bug originated in 011410 update). Bugfix for video posterization issue occurring in some situations (also originated in 011410 revision). Bugfix for not being able to change selections on Other:OnOff Setup:Input Select command.
  Back to Forum: Video Processors
