Originally Posted by
giomania
OK,
I am trying to get my head around how I am going to set up my Radiance XS-3D given all my sources and displays. So, I created a little document to help me in the process; see attached.
I have the Input memory resolution and output config memory and resolution assignments in the default configuration. The idea is that I will modify the particular cells as I make changes to the various parameters.
Any input on this document would be welcome.
Mark
Edit: Alot of changes to the document as my knowledge has increased while reading (and re-reading) the pertinent sections of the manual. I am now thinking that maybe I won't need to utilize all the input memories for the sources coming from my 4x4 HDMI switch, but we will see how they "behave" (EDID) when I get this all set up. I do have some anomalies with the RS-35 to account for, as noted in the last page of the document; this information was gleaned from Greg Rogers' review of the RS-35 in WSR circa 2010.
I have made significant progress in my research and planning for the installation of the Radiance XS-3D into my dual-display setup. Attached is the updated document.
It turns out that my configuration may be simpler than I orginally thought, as both displays should (optimally) be sent either 1080/60p or 1080/24p. However, the RS-35 has an issue handling 1080/60p HDMI 4:2:2 with Video levels, so Greg Rogers recommended sending either 1080/60p HDMI 4:4:4 or 4:2:2 with manual selection of PC (Enhanced) levels in the RS-35, and then re-calibrate black and white.
I realize that
ideally the HDMI levels (Video or PC) be matched between sources and the Lumagen and between the Lumagen and the display device(s), but can a mismatch in the output be overcome by adjustments in the display device?
Is there a way to set the Radiance XS-3D to
output 4:2:2 with PC (aka Enhanced) video levels? According to the Output HDMI Format section on page 17 of the manual, I do not see where this is possible:
Output HDMI Format
You can specify the digital output range as “RGB-PC level” (e.g. for 8-bit 0 to 255) or “RGB-Video level” (e.g. for 8-
bit 16 to 235). “YCbCr 422” is the recommended output format. For the HDMI RGB output, setting the level as
video allows blacker-than-black and whiter-than-white. The command is:
MENU ® Output ® Styles ® [Style] ® HDMI Format ® Type ® (YCbCr422, YCbCr444. RGBPC
level, RGB-Video level)
I did find that you can change the HDMI level on the input, as noted in page 19 of the manual:
HDMI Level
This command specifies if the HDMI inputs use video levels or PC levels. he input video level should be set to
match the expected range of your video source. A mismatch can cause the image to be too dark or bright. An
output video level mismatch can also have the same effect. The command is:
MENU ® Input ® HDMI Setup ® Level ® (Video, PC)
Mark
Edit: File removed, as there is a current version posted below.
Edited by giomania - 8/1/12 at 10:53am
