AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G Elite KURO Owner's Discussion Thread
The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 425
post #12721 of 28732
Originally Posted by drool6 View Post
.......This is a hassle b/c I always have to set my PC mode to the content i'm currently watching.
I hear that the ISFcc modes have the PC settings locked, unless I use ControlCAL to change them. I know the ISFcc modes can be copied from one input to another. So, is it possible to have different ISFcc Pure Cinema modes for different inputs, even though other modes (like pure and performance) will remain the same from input to input unless manually changed?
In a word....yes. This has been an ongoing discussion for the past few days, so you might find it useful to go back a browse some of those posts. Like you, I have found that there's no one-size-fits-all PC mode, so that's precisely the solution I'd recommend- copy the ISF calibration to other memories/inputs and only vary the PC mode.
post #12722 of 28732
I recently purchased a 111fd and am thrilled with all but one aspect. I am watching TV and blu rays, and gaming, in between running the break-in images and everything looks wonderful- except hd basketball. Now sd basketball also looks bad, but it always looks bad. HD sports on my old toshiba LCD (which the Kuro smokes in every other way) looked as good, if not better than what I see now. Dissapointing. the cloe-ups look great, but the ful court shots have an excessive grainy-ness that is distractiing.
I have a comcast cable box hooked up via HDMI sending 1080i (also tried 720p) and I use the settings on the first page of the settings thread.
Is pure cinema somehow hurting things? Is it just a sympton of the tv not being broken in yet? Any sugestions on different settings would be greatly appreciated.
post #12723 of 28732
It's definitely not anything that will change with "break-in." If other channels are looking better, it could very well just be these particular channels. HD channels vary widely in quality.
I would think PC mode might affect the quality of motion on your sports channels, but it wouldn't add a "graininess," as you describe. What's more likely is that the Kuro is just revealing the weaknesses in your Comcast signal. I've noticed that many LCDS have a noise reduction that kind of flattens the colors, for lack of a better description. So, maybe you could try some other AV modes and try tweaking the noise reduction picture options to get a more desireable result.
post #12724 of 28732
How does on use the same source on two different inputs?
Joel
post #12725 of 28732
Sure, bu it is not just channel to channel, it is all basketball games versus all shows or movies. The best example is that on ESPN, sportscenter or close ups during the game look much better than wide shots of the motion. So the quality difference is on the same channel.
I will fool with the different modes tonight and report back. I was hoping to keep the same settings for all sources (I run everything through an AV receiver, so it makes things much easier), but if I must use different settings from different things then I will.
post #12726 of 28732
Joel
I wouldn't do it that way, but others (turbe, for example) have put an HDMI switcher into their system for this purpose. If you really need to have all the PC modes available with your ISF calibration, that'd be the way to go. For me, I'd just use two memories on one input for two different PC modes.
post #12727 of 28732
I find TV signals are so different from my other sources that I need different settings. I run my TV tuner to a different HDMI input on my Kuro and just run optical out from the box to my pre-pro for when I want full surround.
What about screen size? Some of those stretch and "uglify," so you might want to experiment with those too.
post #12728 of 28732
Actually, I really didn't use the hdmi switch for Pure Cinema, I wanted to have a set of memories to experiment with... but you could use the additional memories on another Input for PC or another colortemp, something else?..
post #12729 of 28732
Oops, sorry to have misrepresented your setup. Thanks for clarifying.
post #12730 of 28732
It's just that basketball is an ugly sport, and you only recently noticed.
post #12731 of 28732
I had one memory set to PC Off, but I found that Advance has been working fine for me....
I may go back to using one for Advance and one for Standard though (for my D* Source).
The one problem (is it considered a problem?) with having your own gear is that you want to try different things instead of just sitting back and enjoying content on on your calibrated Display (at least a problem for me).. reading the forum(s) and seeing what others are doing doesn't help..
post #12732 of 28732
I have a receiver with DUAL HDMI OUTPUTS. Works great. Yamaha RX-V3900.
Joel
post #12733 of 28732
Originally Posted by cklim55 View Post
I can't wait to play a blu-ray disc. I may purchase Wall-E to watch. Everyone says it's a good disc to watch on blu-ray.
cklim .... do yourself a really big favor and pick up The Dark Knight! This is right at the very top of the list of movies that will show off the capabilities of your new 111. Trust me, I've got around 70 BRs now and this movie really opened my eyes as to just how good the 111 really is. The scenes that are shot with the IMAX cameras are just spectacular!
Glad you pulled the trigger on the 111, it truly is a great set, and the more you watch it the more you will appreciate it.
post #12734 of 28732
My Yamaha RX-Z7 does this as well--very useful if you have a plasma and a projector. (I wish! )
post #12735 of 28732
Does anyone use the Pioneer "Control" jack in the back of the plasmas to allow it to communicate with other Pioneer gear? Have you found it useful?
Finally, does it take a 3.5mm plug or a 2.5 mm plug? (Just wanted to know to finalize my cable pulls before the 151 gets mounted on the wall next week--so far just running 3 HDMI cables and 1 cat6 cable. Haven't decided whether to run a mini-plug cable through there or not.)
Thanks in advance for your help!
post #12736 of 28732
Those proprietary control systems are pretty outdated now that most people with better HTs use a universal remote, and HDMI has its own built-in control system (CEC).
post #12737 of 28732
I don't have a projector, but since they can be SIMULTANEOUS...I can calibrate both inputs with different settings to DOUBLE my choices for either PS3 or Cable Box, etc...
post #12738 of 28732
Originally Posted by dssturbo1 View Post
yes, it will output up to DD 5.1 from the internal atsc/qam tuners to your avr. but it will not from input sources such as hdmi.
Is this accurate?
I am expecting delivery of a 111 early next week. In the meantime, I am researching receivers. The lack of Deep Color is scaring me away from the SR5002, however page 90 of the 111 Owner's Manual suggests I can connect BR to 111 via HDMI and the 111 would route 5.1 over Optical back to the AVR, giving me Deep Color and 5.1(I do not need lossless at this time). Is that true or false? Am I misinterpreting Page 90?
edit: thinking about this, I could get the same result by connecting the BR Optical out to the AVR. Still nice to know whether or not 111 will output 5.1 from HDMI input.
post #12739 of 28732
This is what I am afraid of in switching to a 151. I have a LED LCD now and there is no noise whatsoever. I think it's called dithering. From what I've read it's inherant in plasma technology. Any solutions to this? I'm kindof thinking of switching to PDP for better motion handling, color, and off axis performance; but the PDP noise is kindof an issue for me.
post #12740 of 28732
I have a Pro-111FD, which I bought in November.
Just today, when I turned on the TV, I heard a repeated clicking noise. I didn't notice any performance issues.
When I turned it off, it went away. It came back when I turned it on.
Any suggestions?
I'll probably call Pioneer in the morning.
post #12741 of 28732
Any suggestions?
Does it come from the speakers or from the electronics? I know the fan can click sometimes when it switches on/off.
post #12742 of 28732
The electronics.
It could be the fan.
Anything I can do to make it stop?
post #12743 of 28732
The electronics.
I hear mine periodically, but I've kind of tuned it out. It's not frequent or otherwise intrusive. Does yours seem to occur too often? To answer your question, I don't know how it could be made quieter or stopped completely. I suppose if you really couldn't stand it, you could try to set up an external cooling option behind the panel that keeps the fans from ever coming on.
post #12744 of 28732
hey
got two little issues i am wondering about
1. is the plasma supposed to give a little hiss? it makes a noise which at night can be annoying when watching a movie on low volume
2. the IR box is going crazy. any way to solve this?
thanks
lorien
post #12745 of 28732
Today was the first time I've noticed it, I don't think it's happened before.
The clicking occurs 3-4 times a second.
post #12746 of 28732
Originally Posted by Lorien View Post
hey
thanks
lorien
Do you mean the infamous buzz? That's similar to the sound a flourescent light can make.
What do you mean by "the IR box is going crazy?" What's an IR box?
post #12747 of 28732
No, that's not the fan click I'm talking about. I'd call Pioneer service tomorrow.
post #12748 of 28732
Well, the 9G Kuros in general will have better black levels than any other TV (at least any I've seen). In any content with black masking bars, many of us particularly love the way those bars just disappear in a darkened room. On any other TV I've seen, there is still enough light in those bars, as well as the black portions of some scenes, that they kind of "glow." You don't get that on these TVs.
I've been studying the black bars very critically for the past few weeks, and you are right.
They are perfect. :-)
post #12749 of 28732
Why is the TV mad at me? I thought I treated it so nicely. Hopefully it turns into nothing tomorrow.
post #12750 of 28732
Yeah...maybe there's just something caught in the fan or something easy like that. In any event, best to adhere to all the warranty terms and let the "pros" handle it. Good luck, and report back on what you learn.
