AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G Elite KURO Owner's Discussion Thread
The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 511
post #15301 of 28738
First I would like to say thank you to everybody for the great information on this forum.
So finally after saving for years for my dream HD system, I finally threw down and bought the 151 and SC07. To my dismay I am able to hear the dreaded 151 buzzing from my seating position which is 17 feet away so from reading the information here, that either means:-
1) I am in the minority and have supersonic audiophile hearing?
2) Just unlucky and got a defective set?
I'm still within my 15 day return window, so my question to this group is:-
1) Has any other supersonic audiophile had any success with returning a buzzer set and received a satisfactory resolution with a replacement i.e. is it worth going through the return process or should I just cut my losses and consider an alternative manufacturer if I can't live with this.
2) Does anyone have any recommendation on the next best set for a replacement?
Many thanks,
post #15302 of 28738
Originally Posted by progprog View Post
Oppo DV-983H or BDP-83.
The DV-983H seems to no longer be available since the BDP-83 is considered its replacement and is due for release soon. I know this because I wanted to buy a 983 a couple of weeks ago and couldn't
post #15303 of 28738
Many thanks,
http://www.avsforum.com/avs-vb/showt...044254&page=41
take a look in that thread there is much talk about that. However I would try powersave mode 2
post #15304 of 28738
Originally Posted by mopar426 View Post
Yes, ADVANCED is were its worse and that makes total sence. In my technical terms "OTA eggs are way too scrambled". I usually have the best performance on SMOOTH or OFF.
For the time being its important as I'm testing out the Oppo BDP-83 and would like to see if truly, what the Oppo says its doing, is actually being done. With that I'm finding myself switching my HDMI to PC and back alot.
Just like trying to see my DENON AVR-3805 menu on the Kuro. I can feed the AVR display "out" to AV "in" but the 111 only does PIP with the ANT IN and any other source. I have a way to do PIP with my AVR menu on the left and the Blu-ray picture (or any other) on the right but have yet to purchase the equipment to modulate the signal going to my ATN IN. Fun stuff. I do belive it will work tho and yes, this is important to me too.
mopar
If you can borrow a DVDO outboard scaler, you can plug the Oppo into that and use the scaler's Info button to see exactly what's coming out of the player.
post #15305 of 28738
Originally Posted by JlgLaw View Post
Maybe someone with more info can clarify this, but I just got off the phone with Pioneer (Parts) seeking to obtain the latest firmware for the 111. They took my order, but informed me it would be several weeks before the USB would ship because they (Parts) had recently gotten notice that a "bug" was found in the last firmware update and they should have a fix within a couple of weeks. They couldn't tell me anything about the "bug," but said they are working on it.
If this has already been noted somewhere, or if it is BS (which is always possible when dealing at that level), my apologies, but I figured I'd pass it along.
Jim
There were reports on these forums of problems with the USB thumbdrives that Pioneer was using and not with the firmware itself. I have only seen one report of a user who had problems with the firmware. This firmware does seem to be sensitive to the type of USB drive it is installed on so maybe that is the bug they were talking about.
post #15306 of 28738
Thank you Roman - Sorry for posting in the wrong forum
post #15307 of 28738
Oh no worries at all There is just allot of info there and hope it works out!
post #15308 of 28738
Originally Posted by jmschnur View Post
Unplugging for 10 minutes or so it should help-perhaps it is locked in a retailer mode.
Joel
hi - i finally tried to reset this TV - its a Pro FHD1 pioneer
and it was unplugged for over 30 mins - but it didnt reset to anything - when it was plugged in again - it just was the same - nothing came on that gave me a option for home mode etc.
does anyone else have a clue ? i did notice the HDMI cable is connected to input 3 - it has 6 inputs - not sure how many are HDMI - i scrolled from input 1 to input 6 and noticed that only input 3 says Dynamic -- the rest say standard - but there nothing connected to them -
i was not able to connect his cable to another input - he will have to do that - i suggested he try that - i cant think of anything else as to why - input 3 is not allowing me to change it and it stays on Dynamic
very strange -
does this sound right to anyone here who has Pioneer -
actually does anyone have this model that can help out here -
its the PRO FHD1 50 inch model -
thanks -
post #15309 of 28738
very strange -
thanks -
Are you positive that it's stuck on dynamic? Have you tried going to the Dynamic setting and pressing the enter button on the remote? Many settings will be locked out in dynamic mode but you should still be able to switch to a different picture mode.
The remote control may also have a button devoted to cycling through the picture modes. The newer Elites do.
post #15310 of 28738
8 years ago I purchased the 620 and I still love it but just last month a problem with calibration started and I would need to pay 800 minimum to fix. I figured time for a new one. Now which one...
I purchased the 5020 from Costco (still in box) because they allow returns while I'm deciding which model to go for. At least I know that I have my hands on one before the Pioneers are all gone.
Here are my questions:
1. Do I buy the 111 or spend another 2k for the 151?
2. What is the difference between buying from auth dealer or not, and does it matter?
3. What can I do with the 620 that I currently have? Is the TV good for parts, do I just junk it or try and sell it and they can spend the 800 to fix? Suggestions?
I'm almost there... just need a little more information and some friends to support me with my decision. My girl friends have no idea what I'm talking about when it comes to electronics - pocketbooks, we're on the same page - TV's, clueless. (female member )
post #15311 of 28738
drmroth if you want bigger and can do it go for it
The most important thing is to check resellerratings dot com on the vendor and if you trust them.
post #15312 of 28738
Originally Posted by hhaller View Post
So has anyone here moved from a 720 plasma to the 9g Kuro (or any other 1080p plasma, I suppose) and noticed an increase of pixelation on broadcast TV? I went from a 5080 to a 111 and I can't get over how bad the pixelation and artifacts are on some channels. (Fios)
My 151 arrives Wednesday. Moving up from a 940 (720p).
Are you using a HDMI cable rated for 1080p (1.3a category 2)? I am not and just ordered (from Monoprice, of course) new ones to connect my BDP-83 and AVR to the 151. I'll use one one on the DVR, too. I have FIOS and the HD channels are not re-compressed - that's about as good as it gets.
Even though you are only getting 1080i max out of your DVR/STB, it cannot hurt to upgrade your HDMI cable to a higher speed rated one.
This may or may not help you, but it's worth consideration.
post #15313 of 28738
Originally Posted by syswei View Post
Sorry if this might have been posted earlier somewhere, I haven't monitored the Pio threads much....but the May issue of Home Theater mag has a review of the 141FD and in the opening paragraph it says:
Pioneer panels will continue to be available through the end of 2009, including the Elite Siganture Series monitors.
I know that production is slated to end much sooner than that, but if the info is accurate (i.e., from people at Pioneer who might know), it might indicate how long Pio expects its inventory (including what remains to be built before final shutdowns of all plasma production) will last.
I would not trust what HTG magazine says about it, I would also not count on on there being any real supply of new sets lasting until the end of 2009. Most all of the reports from people who have some insight about the assembly & supply chain of the Pioneer sets, is that, as of this month production of anymore new sets in the US has pretty much already been shut down.
post #15314 of 28738
Originally Posted by drmroth View Post
. . .Here are my questions:
I hate to say this, but IMHO, the most important determinant IMHO is what the extra 2 grand spent on a luxury, non-appreciating item will do to your overall financial situation. If the impact will be small, then I say--go for it and you won't be sorry!
As I recall; however, you also have an ususual mounting situation, so I'd make sure the larger size articulating mount will still fit in your particular application (and that you have at least 8 feet of distance to watch it from) before taking the plunge.
2. What is the difference between buying from auth dealer or not, and does it matter?. . .
The difference is that Pioneer officially says they will only honor the warranty if you purchase from an authorized dealer.
However, I think the benefits of buying from an authorized dealer go a little further. A dealer who has paid the fees to be an authorized Elite dealer generally has the financial wherewithal to do so, and often traffic in other high end products as well. These types of folks tend not to be "fly by night" organizations and they are used to catering to a discriminating, knowledgable crowd (exceptions exist, of course).
Moreover, they may be more likely to be around and have a solid return policy if there's trouble. I also like the fact they are playing by the rules, and value the desigation. The small savings going unauthorized becomes really minimal when amortized over the life of the television. Obviously, there may be excellent dealers who are not authorized, but I felt a lot better going this route. YMMV, of course.
. . .My girl friends have no idea what I'm talking about when it comes to electronics - pocketbooks, we're on the same page - TV's, clueless. (female member )
Don't worry, we're here for moral support (on the TV purchase that is--don't know much about pocketbooks!)
post #15315 of 28738
Correct
post #15316 of 28738
That is not correct since if you had to pay a fee it would be pretty easy Never seen them charge a fee Again even authorized dealers you should check resellerratings dot com on
post #15317 of 28738
Once they run out THAT'S IT! They ARE NOT going to start manufacturing them again to meet demand.
post #15318 of 28738
Yup here is what I posted in the supply thread
The 141/101 will be available longer and KRP's as well.
111's are on their last leg ONLY few nationwide
151's are the next to be gone and last shipment is coming any day period.
post #15319 of 28738
Originally Posted by Jim Boden View Post
Sounds like it's left over from April Fools' Day to me.
I'll make the room work... I'm going to go with the 151 - Thank you for your help
How long do I have to be on here before I will no longer have "new member" under my name? Although, I'm just about to turn 40 and I don't want "senior" under there either
PS - don't be surprised if I still have more questions tomorrow - although I'm just about there!
post #15320 of 28738
Keep posting and you will get there
post #15321 of 28738
Hello,
This may be a crazy question, but does anyone have the box that their 111-FD came out of ? I need to know the measurements length x height so I can see if it will fit in my van without laying it down. I'm suppost to pick mine up Sunday , and my truck broke today ..... Just having some sorry luck!
post #15322 of 28738
Originally Posted by webdrifter View Post
Hello,
Carton Dimensions 52-7/8 x 38-3/8 x 20 (W x H x D)
post #15323 of 28738
Thanks Roman.
post #15324 of 28738
Good call!
Nobody ever gets buyer's remorse for getting the larger TV.
That would be like feeling bad for having a large p*n*s.
post #15325 of 28738
Thanks, I did see that. But having had a bad experience with one of their Blu-ray downloads, I now order the disk (or USB) directly. (I figure there is less chance of ME screwing it up.)
That said, when did that firmware get released? I asked if the 0401 firmware WAS the fix, or if that is the firmware with the "bug" (her language) and she indicated the 0401 WAS the problem. I do question that, because it is still downloadable and I didn't think Pio would have it up if it was a problem, which is why I posted here looking for clarification.
Jim
0401 is the correct firmware. I downloaded it and it worked out fine, but if you have 0401 already then you are good.
post #15326 of 28738
His posts are always entertaining when he gets pissed! While I know that D-Nice is knowledgeable, I think others are as well. I'm (very slightly) inclined to believe the "consensus" amongst these sources, but I'm also aware that none of them are directly from the horse's (Pioneer's) mouth. All of which continues to to leave the Pure Cinema discussion somewhat unsettled and confusing for most users.
I guess I see why they dumbed down the manual to the lowest-common-denominator, but Pioneer really should have provided a technical manual or other documentation for owners who actually want to understand the specific adjustment parameters & options available in these sets.
I built a simple phototransistor circuit and actually measured the refresh rate on my 111FD. Here is what happens when fed a 1080p/24 source:
Off - 60 Hz refresh
Standard - 72 Hz refresh
Smooth - 60 Hz refresh
Advance - 72 Hz refresh
Here's my post in the non-Elite thread:
http://www.avsforum.com/avs-vb/showt...7#post16236997
post #15327 of 28738
Please limit discussion to Kuros. Thanks.
larry
post #15328 of 28738
Are many of you guys using the Room Light Sensor (just Mode 1) and see it as providing good results with regards setting the brightness level for your viewing environment?
Are there any reasons why it shouldn't be used in Mode 1, i.e. will it have a negative effect on the image.
I've tried it in Pure Mode and to my eyes it adjusts the brightness level quite well, but if there are other areas affected due to it being enabled hence deminishing picture quality, I'd be interested to know.
post #15329 of 28738
I have been using ISF Auto which uses the room sensor and the screen looks great. And with that being said, I know I am not using ISF auto correctly. I just use with whatever defaults it came with when activated with controlcal. I seriously have no idea what people mean when they talk about the 111 with dim colors and gray whites. Each day I have this 111, it just seems to get better. When I first got this I was definitely going to get it calibrated and probably still will. But with how great it looks, I am not in a rush to do so.
I welcome others to chime in on their experiences with ISF Auto.
-David
post #15330 of 28738
Activated ISF-Day and ISF-Night with ControlCal using D-Nice settings. In a word, WOW! It's hard to describe unless you actually see it. Flesh tones still very accurate and colors pop even more off the screen. Blacks look blacker and whites look whiter. ISF-Day breaks right through my very well-lit room during the day. Tremendous.
