Originally Posted by progprog
It has to do with the panel receiving a command that activates the internal tuners, as far as I can tell, and something in the IR power sequence that Harmony uses does that. (It's not Harmony, but the command itself.) Further, it seems to be exclusive to an IR command. I get it sometimes with my IR-controlled Kuro, but never with the serially-controlled one.
This is normal behaviour with my 111FD if I try to switch inputs without allowing the panel enough "start up" time. I don't use the tuners in mine, but see it when switching HDMI inputs.
). Nothing seems to work. Suggestions?
). They are part of a procedure for a certain type of "self-calibration," and that procedure doesn't apply when you are getting a professional calibration done.
