Originally Posted by
leftkidney
yes its staying red when its off
could it be that I have my energy saving settings of whatever its called turned off? - is yours turned on?
I turned it off just about the first thing I did
I have it set like this
Energy Save= Off
No Signal Off= Enable
No Operation Off= Disable
is there a place in the service menu or something that shows is there are any error codes? - I have the controlcal software - I have also noticed that there appears to be an interlacing issue with some 1080i content on history channel, but as anyone should know history channel has been the worst HD out there for years they have been doing things to the picture aspect and audio problems as well so I dont know
an update
I turned off the display using the main power button on the bottom (which I never do really) and waited for the red light to turn off (it took like 30 sec or more for the caps to drain and the light to go out) then I turned it back on and it was green like it should be and then I turned it off - it stayed red for about 5-10 seconds and then turned off
so I know for sure now that it was not something that was on for the whole life of the display because not only did it turn off like the other person said but it also doesent light up at all in the back of the display and when looking at it I notice that this is how it should look - no red glow in my dark basement when the display is off
I will report back if it happens again, and also I was having a problem with a "red something" or whatever it looked sorta like how a LCD can be red tinted blacks, it was sorta like that but not uniform over the screen, mostly in the bottom and bottom right - I am going to bed now and will see if this has gone away as well
