AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G Elite KURO Owner's Discussion Thread
The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 897
post #26881 of 30260
Originally Posted by dmusoke View Post
My plasma is plugged into an APC power filter and conditioner. Is this ok or should it be connected straight into the wall socekt w/o the benefits of power filtering and conditioning?
Your APC is fine. I think a bad power supply is a relatively cheap and easy fix.
post #26882 of 30260
Thank you so much, 1forsnow. This confirms my thought that the problem is in the power supply section. Where do i download the service manual?
here you go....
http://elektrotanya.com/pioneer_pro-.../download.html
you may need to view the link with google translate though.
ENJOY!
post #26883 of 30260
Originally Posted by 1forsnow View Post
here you go....
ENJOY!
Thanks HT and 1forsnow:
Called up the nearest service center. They said it will cost about $500 (parts and labor) to fix as the set is about 3 months out of the 2 year warranty. Seems rather steep but i'm rather desparate to have it fixed quickly. RIght now, i;m using my old Sony RPTV and its very yucky(all things red)!
post #26884 of 30260
I'm not sure if this was mentioned but if you purchased your display with a credit card it may have extended your warranty by one year. Check with your credit card company.
post #26885 of 30260
Shucks!...credit card which was discontinued.
post #26886 of 30260
Originally Posted by mark_b View Post
Would someone here be able to tell me how I would go about removing streaks from the bezel of the tv? I have a 151FD.
I've has anti-glare peel on my old screen after wiping it with tap water. Since then, I've found distilled water is the answer for the screen and bezel. If that doesn't work, then the rag is dirty with grease.
post #26887 of 30260
The service center called again today and said the price went up to $900 Is it worth it? Are there any new TV's out there that have the KURO's image quality or come even close to it?
David
post #26888 of 30260
David
nope.....invest 900 or spend a good 2-3k for a panny vt30, tough choice
post #26889 of 30260
David
is this panel on a stand or mounted to the wall? 900 bucks seems steep for sure!
IMO since its currently dead, i would at least TRY to fix it before forking out money for a new panel. if you download the service manual, there is a detailed flowchart that walks you through failures of this sort. if it is a power supply, it seems relatively easy to replace yourself and im sure mr google can find you a cheaper power supply.
and i also agree that the vt30 is a great panel if you need to go that route...
post #26890 of 30260
David
Why not buy the part and install it yourself?
post #26891 of 30260
The plasma is mounted on the wall. The dealer said the price is high because the power supply parts are rare to find? Not sure if Pioneer design a custom power supply for the KURO or its just a stock unit you get from anyone. I believe the panel is fine and that the power supply section is dead accroding to the error codes .... red power light blinking twice repeatedly.
Not sure about the difficulty involved in this but will look into it. Ebay seems to have no power modules on hand for sale. Guess have to go direct to Pioneer.
post #26892 of 30260
The AXY1201 power supplies are easy to find, but direct from Pioneer at $401.95 they are pricy.
http://parts.pioneerelectronics.com/...uctNum=AXY1201
However, through many TV parts suppliers, they can be found for under $150.
http://search.yahoo.com/search;_ylt=...&cop=&ei=UTF-8
post #26893 of 30260
John:
Thanks for the links...
1) Do you know if these are these genuine pioneer parts?
2) Does the 151 only have 1 power PCB (AXY1201) and not two or more? In short, any secondary power boards? The screenshot in the service manual seems to show a section of 2 boards they call "POWER SUPPLY UNIT" The one on the right is the AXY1201(i believe) but what of the one on the left?
Thanks again!
David
post #26894 of 30260
David,
I honestly don't think you can get the performance of a 151 out of any a 65VT30 and your money is better spent on getting your 151 working again.
The sticky issue is to try to do it yourself for a $150 part or pay someone else to do it for $900 (which probably contains the same $150 part).
A good starting point is to download the manual and see if there are any difficult instructions where you get totally lost. I downloaded an English manual for my 6070 and presume that one for the 151 is also available. I wouldn't want to deal with bad translations using a software translator.
post #26895 of 30260
Originally Posted by JimP View Post
David,
I agree Jim ... please see my post above and chime in, if you can
post #26896 of 30260
John:
Thanks again!
David
Yes they are genuine Pioneer parts. You need both boards which make it a unit.
post #26897 of 30260
What is the part number of the 2nd board on the left? I verified the AXY1201 is the one on the right.
post #26898 of 30260
wishing you all a marry Christmas and happy new years.
post #26899 of 30260
You may be incorrect. Here it seems the part # applies to both pieces.
post #26900 of 30260
Thank you so much jmmesch ...relieved indeed and had it shipped next day air .... by the way:
HAVE YOURSELF A MERRY CHRISTMAS AND ALL AVS'ers AS WELL
post #26901 of 30260
have yourself a merry christmas and all avs'ers as well:d
+1
post #26902 of 30260
Well, let me add on a Happy Hanukah to all my lance-men and women here.
Merry Christmas, and Happy Kwanza, or all other holidays any AVR's celebrate.
To all, Happy New Year 2012!
post #26903 of 30260
dmusoke you made a wise choice on fixing your TV. Other people would of gave up and bought something else. Theres no other TV that has the look of the kuro. Not even the sharp elite that everyone likes to rave about. Depth is the key word here.
I was watching pirates of the caribbean 2 and 3 last night and im surprised after 2 years of owning this TV i still say "damn."
The whole movie is reference but the scenes i remember standing out to me in 2 with that sense of depth to the picture was chapter 1, chapter 2 for black level and shawdow detail, and chapter 7 at 32:50 when they're hanging from that ball shape thing. Look at the close up's of the actors faces. It looks 3D and feels like your in there with them. Simply amazing.
Maby Panasonic 2012 PDP's finally matches. Hopefully. What say you D-nice?
post #26904 of 30260
I was watching A Christmas Carol last night. The Alastair Sim 1951 version, on Blu-ray of course. The definitive Christmas classic.
The sharp detail, contrast, the watery deep blacks! Awesome!
Merry Christmas everyone!
post #26905 of 30260
What you all talking about!
My wife and older, adult daughter are wathing the BD of Bridemaids in 1080p DTS-HD Master right now on on our 151, laughing their heads off!
Later, I'll watch what I want!
post #26906 of 30260
I know it's been said here already but...............
MERRY CHRISTMAS EVERYONE!!!!!!!!!!!
post #26907 of 30260
Mod question: out of curiosity why is this thread not stickied while the Official 9G Non-Elite Kuro thread is?
TIA!
post #26908 of 30260
Is it because they don't like us as we are just snobs? LOL!
post #26909 of 30260
Lord of the Rings Trilogy awaits you (if you haven't yet been wowed).
post #26910 of 30260
New power supply arrives tomorrow. Can't wait ... I have refused to watch my favorite HD programs at all on my old RPTV which loves to show all things red and is out of focus Its been a painful experience indeed.
I'll have a friendly neighbor help me unmount the plasma from the wall and hopefully changing the power supply will be a cinch.
