AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G Elite KURO Owner's Discussion Thread
The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 915
post #27421 of 28695
Originally Posted by saprano View Post
I tried lowering the green low, it helps, but then red creaps in. I tried playing with the red and it just doesn't look right. balancing the colors is very difficult. You think you have a neutral picture, then compare it to something else and it looks bad. Watching some broadcast channels the colors are all over the place.
I tried Dnices's settings and it's still green. But those are for 2008 kuros.
And i still have the green patches to deal with.
Hire someone to get your display calibrated.
post #27422 of 28695
We shouldn't have to do that with this TV. Or any TV. Yes i know a calibration gets 100% out of it but i shouldn't have to spend extra money because the color is so far off from normal. And i don't think a calibration can get rid of the green patches.
I spoke to a technician about this. He said pioneer still has replacement displays if he can't fix the issue. What are the chances this happening on a new one?
post #27423 of 28695
No display, and I mean NO display, comes calibrated out of the box.
Also, you don't know what is wrong with your display. Only someone who is experienced with how the display should perform would ve able to tell you exactly what you are seeing and the whys behind it.
The same chance it had with your current display or any PDP.
post #27424 of 28695
Just finished my media room - thought you guys might like to see the KRP-600M in its natural environment ; )
Attachment 240715
Attachment 240716
Attachment 240717
post #27425 of 28695
Very nice indeed.
post #27426 of 28695
Very nice!
post #27427 of 28695
So I have a question with regards the the Elite and the new Apple TV.
With the Apple TV, you ca select different color ranges and based on what i have read here, RGB would be the best choice.
Am I right on this? And, which one, RGB High or RGB Low?
Thanks, Ray
post #27428 of 28695
Originally Posted by Bob Fosse View Post
I have a Harmony One which I would imagine would also allow for transfer of the code to it since it has a learning function.
I wouldn't imagine that it would be possible to PM a code like this? However if there is a way to do it I would sure be interested. Perhaps Pioneer would make it available to the Harmony Data base if someone asked? After all it does not include the entire "factory remote" codes but just this one code. I guess that it wouldn't hurt asking Pioneer or posting about this on the Harmony threads?
has anyone tried using the USB-UIRT to read the hex code in EventGhost, that could be sent via email.
post #27429 of 28695
Of course not. But no displays color should change dramatically from where it's suppose to be. A calibration will make it better obviously but thats not the point. I should not have to calibrate my TV just so i can watch it. Out of the box picture should be fine. And it was.
Yeah thats you. You know the in and outs of these TV's more than anyone. Now i don't know if i should get the tech to come out and check on it or see if your going to be in NY anytime soon? But i don't wan't to have to spend money.
The one thing im afraid of with getting a new display is it can be worse with other problems. But if the tech can't fix the green blobs, i might as well try my luck.
The green on my kuro wasn't too noticeable yesterday watching TV. It's really obvious when changing AV modes like performance back to pure or movie. Almost as if the eye adapts to the green until you compare it to something.
post #27430 of 28695
Or you could just copy the Pronto code from here.
post #27431 of 28695
thanks bodosom, I missed that
post #27432 of 28695
Do you have a link explaining how to get the the code into a Harmony-One?
HH
post #27433 of 28695
No, I don't use Harmony. You should review my earlier posts (and related ones) about getting codes added.
post #27434 of 28695
HH
do you have a USB-UIRT? I used this and EventGhost to send the code to my Harmony 900 in learning mode, after logging into my harmony account and creating a Factory Menu soft button.
post #27435 of 28695
I don't know what a USB-UIRT is (I'll Google it)?
HH
post #27436 of 28695
I had my 151 recently calibrated by Jeff Meier from Accucal. He was prompt, efficient, and friendly. The picture was great before, but after calibration it was significantly punchier and more realistic. There seems to be more contrast, dark detail, and color accuracy. I'm satisfied knowing that I finally have a reference quality picture. I would highly recommend a professional calibration, and I was very happy with Jeff's work.
post #27437 of 28695
Anyone in tulsa, ok area have any suggestions for calibrators?
post #27438 of 28695
Originally Posted by jdmi View Post
I had my 151 recently calibrated by Jeff Meier (UMR @ AVS) from Accucal.
Thanks for your calibration report. I've added it to the flat panel (post #2) lists that are linked in the signature section at the bottom of my post.
Enjoy.
post #27439 of 28695
Check the location thread that's linked at the bottom of my post. Then you can use the AVS user name to look for customer reports for the calibrators who travel to your location. I'm not sure, but UMR (see above) may travel to your area.
post #27440 of 28695
Jeff from Accucal is coming to my house in April , I live near Tulsa, have 2 Pioneer 9Gs, this is his 3rd visit ,highly recommend Jeff !
Mark
post #27441 of 28695
D-Nice, i was reading the settings thread and i found some settings you made for pure and movie- http://www.avsforum.com/avs-vb/showp...&postcount=271
Is it ok if i use them?
They seem to work well in making things less green. I especially like the warmth of movie mode.
post #27442 of 28695
I don't know how I could stop you from using them. Just know I don't know how they will perform on your display.
post #27443 of 28695
Please excuse my post here. Just realized what forum this belongs in and moving my question there. Many thanks,
post #27444 of 28695
Well from the looks of it, so far, it performsreally well. Im no longer bothered by too much green. Pure mode is back to looking natural and....pure. And movie mode looks better than ever. I think i'll be using that the most since i like a warm picture. Im so glad i found these. Just in time my double feature of tinker tailor and dragon tattoo tomorrow.
I'll see if i notice anything thats off while watching movies. But im loving these settings right now. I can imagine what a calibration would look like.
post #27445 of 28695
RGB Low should be RGB 16-235. I believe that is the colour space D-Nice advises to be the best match for the Kuro.
post #27446 of 28695
Now hire Dnice to calibrate your display like he's done for me twice now...
post #27447 of 28695
RGB 16-235 is correct and I am not positive that all devices use the same terms but RGB high is 16-235 on my boxee streaming device. My understanding is RGB high or RGB video is 16-235.
Barry
post #27448 of 28695
Does anyone have any experience with a single/double in-line power conditioner for plasmas? My KRP-600M has its own socket and I'm short of space in the cavity behind the screen?
The company I'm buying my rack power unit from has a small model called the Mira but they are special-order only and have US plugs on them...
post #27449 of 28695
I own a Pioneer Pro 111 FD.
I had a party recently and there were smudges on the screen.
I tried to use a TV cleaning rag and remove them without any luck.
I then sprayed a small amount of windex on the cleaning rag and tried to remove the blueish blotches on my screen. It only seemed to streak the blotch in a larger area. (Windex was stupid.) I've read on another thread that the blueish blotches are just oils.
I then applied water to the rag and cleaned the entire screen. I was able to buff out the streaks.
However, I can't tell if my mind is playing tricks but the picture quality doesn't seem the same.
The clarity isn't there anymore. Colors seem a little blown out. The darks just aren't as dark now. I'm not sure if this is because it's the first time I've cleaned the screen this much.
I'd be surprised if one cleaning could ruin a tv but I guess it could happen.
Am I crazy or did this dramatically affect the PQ?
It may be that I am looking for flaws (because the streaks set off worse case scenarios in my head) but the Kuro doesn't seem to have the same pop and wow factor.
I'm cool with the the straight truth because I've had two great years with the TV.
Is it a lost cause or is there anything I can do to save the TV?
Your input would be greatly appreciated.
post #27450 of 28695
Crazy..... final answer
Nothing you've done to your display has any impact on black levels or PQ in general beyond blurring that may happen with the streaks. Even that is pushing it.
