Originally Posted by Traxion
Hey Guys,
I have a little problem and was hoping to get some help. I have had my E-Lite 5020 (PRO-111 FD) in storage for about 6 months due to moving and renovations, and now after powering it up for the first time, my panel seems to be buzzing far more than before. I know that some panels have more buzz than others, but mine has always been fairly quiet and now it's quite loud. Any thoughts on why this would suddenly happen?
Anything I can do? I have a very nice power conditioner (APC S15) that has a grounding screw on the back of the unit that it recommends components be tied to prevent ground loops from creating a hum in the audio system if one is present (unlikely to be a problem, but I guess they put it there just in case) - would grounding the TV make any difference? Since that feature is more for resolving audio hum, I doubt it, but I thought I'd put it out there anyway. Thanks for any help...
EDIT: Apparently, ground loop is a common issue, and something I might want to address even if it's unrelated to this. Funny, every other surge protector I've owned in the past has made no mention of this...
Hey Guys,
Had my Pro-111 in storage for 8 months also due to moving and renos etc. Set it up and turned it on and it had a above normal buzzing sound that I did not like. I said oh no I have a buzzer panel but it never buzzed like this before.
However, the good news is that it went away after a week of normal viewing. Maybe if these panels are not used theres a build up of static electricity or dust or something. Hopefully your buzzing will go away with normal viewing use.
Edited by Edllguy - 2/6/13 at 6:53pm
