Originally Posted by rs350z
i have a couple of questions:
1) i currently have the cp-6381's in a dedicated room that is 28 x 13 using all Classe gear (200 watt amp, cp-60 preamp with phono). i really like the sound, very good bass, nice soundstaging, etc... i do have room treatments for the 1st reflection and tube traps in the back corners. speakers are close to 10ft out from the back wall, slightly toed-in. i am thinking about going to either a nice tube integrated amp or possibly a mcintosh integrated amp (ma-6900/ma-7000). since i moved to a small town far from any dealers, what would be a good tube integrated amp that would power these speakers? i mostly listen to jazz/blues/new age with some heavy rock thrown in, not at earth shaking levels.
2) i have always liked the sound of usher speakers. my other 2 systems in the house have the x-719's and the v-601's which sound very nice. so a couple of speakers that i'm curious about are the 8571's and the 8871's. it looks like the 8571's use the same drivers as my 6381's and the 8871 use the dual woofers. besides the much better looks, would there be a huge increase in sound performance compared to what i have now? i have nice tight bass with the 6381's in my room now.
thanks
thanks
I have always liked the Classe gear: warm, solid, powerful. A little dark, but overall a very strong lineup. I have to confess I have converted a LOT of people to the audiophile world. My primary recommendation? The X-718. The silk dome tweeter does not have the resolution of the DMD, but it is warm, soft, and very musical. It hides flaws and scales well. It is a great starter speaker. It could easily be somebody's last speaker too, it's that good. Your 6381s are the same--great design, very musical. But--
You already have all that. The problem is in moving up, the recipe changes. If you want to move up the chain now, you already have musicality in spades. You will be increasing the resolution of your system. This will cost money, but you seem like you want to go there. I have heard the 8871s and 8571s. I haven't bothered with the BE-10s because they are so far out of my range. The 8871s are more marketed to the home theater crowd. I think the 8571's have plenty of bass and will do whatever you want them to do, especially if you're happy with the bass you're getting out of your current speakers. However, the resolution of the speakers is far above the 6381s. Not only do you have the DMD tweeter, you also have a dedicated mid-range. These speakers have extraordinary resolution and will put you in the first tier of the speaker pantheon. However, like all speakers, they are not perfect. I have found that the drivers aren't always as well integrated as they could be. Maybe it's a phase/timing/equipment issue, but a well set up tube system can make a stunning system out of them, so maybe it's less the speaker than the supporting electronics. Know for sure that they are very conscious of supporting electronics, and will show it. This is the downside of the top tier speakers, their resolution will show all the deficiencies of what's upstream in the signal chain, and they aren't bashful about it.
I think you Class gear is worth hooking up to them to see how they perform. It would be interesting to hear! If you are looking to simplify/combine your gear upstream, at this tier the field narrows considerably. I am an unabashed fan of Balanced Audio Technology. They have both tube and SS gear, but their tube gear rocks in my book. They have an integrated tube amp that's worth a look. Other contenders could be Acoustic Research or Cary depending on your personal preferences. Cary stuff has more of the bloom associated with tubes, AR a cooler presentation but still that tube liquidity. BAT falls in between. There are others. Check the forums at Audioasylum -- there is no end to opinions over there! (That may help or not!)
Good luck and have fun!
Aloha,
Griller
