AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Quick question about the Lexicon MC-12B
post #1 of 7
If I get a Blu-ray player that decodes the new audio formats can I listen to them with this unit?
post #2 of 7
If the player has the decoding and 6 channel analog outputs yes.
With the MC-12HD you can also listen to them over the HDMI connection if the player decodes the formats.
Shawn
post #3 of 7
interesting note:
most of the new BD players coming to market no longer output audio over both HDMI and analog/digital connections at the same time: you have to go into the setup menu and select one or the other
post #4 of 7
Shawn
Are you sure that the MC 12 HD will decode them over HDMI ?
I just bought a new MC 12 HD and I could not find any imformation on their web page
post #5 of 7
"Are you sure that the MC 12 HD will decode them over HDMI ?
I just bought a new MC 12 HD and I could not find any imformation on their web page "
The player has to decode to PCM and then passes that to the MC-12HD over the HDMI connection.
Shawn
post #6 of 7
Some BD players decode internally and some don't -- the ones that don't bitstream the signal to the pre-pro to decode. Since the Lex doesn't decode, you need a BD player that decodes internally.
I believe the BD players that decode internally pass the decoded signal through analog outputs. If you have a 7.1 set-up, make sure the BD player you choose has 7.1 analog outputs. Some only have 2.1 outputs.
post #7 of 7
Which BD player or players are you considering?
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
